Whining / Whirling Sound from Engine
You know him right?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I was driving today and I noticed this weird whirling sound coming from the engine. It ONLY happens when the car is in motion so that makes me wonder what the problem is. About 6 months ago, the alternator starting whining when I press on the accelerator, but this sound is different and only happens when the car is moving (forward...i haven't listened for it while i was reversing)..anyways, does anyone have any idea? Do you think this is just the last warning sign from my alternator???
thanks
thanks
thanks
thanks
Its your alternator belt or the alternator itself ...simply dieing most likely. Check it out when you get a chance....make sure the tension is adjusted correctly. Also check the PS belt. Make sure nothings binding. Let me quess.......sorta sounds like a super charger in first gear ?
Bagel Bomber
You know him right?
the noise occurs when the car is moving..its not anymore significant when i'm turning or going straight...it has nothing to do with the acceleration though...like when i'm going down a hill I will put it in neutral so the engine is quiet and the noise is there...and as I slow the car down, the noise slows down too. When the car is stopped, I hear no noise at all (well except for the whine of the alternator which has been happening for many many months now)
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by subbuzz
supercharger??
wd40 ftw
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by PimpCL23
i dunno... i prefer Italian or Ranch myself
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
say: zouts
you dont have a turbonator right?
have you looked around/under the car? ex. if your splash guard is broken and hanging down its bound to make noise. check for anything that the wind could be hitting.
You know him right?
I still have to check out the belts and stuff...I replaced the waterpump/timing belt around 120km...I can't remember if the original 'whining' sound started way back then..I doubt it..but who knows..
You know him right?
it definitely follows my speed....if i'm coming to a stop I will put it in neutral so that my engine is idling and i can hear the whirling down as I come to a stop.
You know him right?
when I told my father about the problem, the first thing he thought of was a wheel bearing or something similar since the noise occurs when the car is rolling...could this be true?
(Mid-Atlantic)
(Mid-Atlantic)
could def be true
09-15-2015 06:44 PM
