Where should I start
I just bought a 98 cl 3.0 with a little over 202k. For the most part everything about the car is as ideal as can be for a 14 yr old car. It's got a few issues I need to iron out though.
1. Starting with what I believe to be the starter. It has shows very labored starting but usually starts around the 4th try maybe. What do you think this could be?
2. After running for a little while it starts to overheat which I'm assuming could be a thermostat issue. Any other suggestions?
3. I think my power steering pump may be bad because when the car is sitting still it's very difficult to turn the wheel (more difficult than normal of course) but when the car is moving its fine. Where should I start with this?
4. When the car is in motion, it makes a scraping sound on the right side. What is this?
5. The power locks don't work for either door. Also, the driver's seat will not move neither forwards nor backwards. Maybe the seat's motor or fuse is out? Also, the passenger seat slides around when I drive. How do I keep it stationary?
6. FINALLY, the trunk lever is inoperable from the inside of the car and I can't get into it.
I'm fine with spending necessary money on fixing the car because I'm pretty proud of it being my first buy, I just need help as to where to look to start fixing it.
rockyboy
08-04-2024 10:35 AM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
