Where to hook up the OBDII scanner!!!!!!
Jhatt from Ludhianna
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
Hi All,
I have a 98 2.3cl, the engine light came on and I cannot locate the OBD scanner plug on my car. Normally it should be under the dash driver side thats were one would find it. But I didn't see that and poked around but didn't find it.
Can some help me locate the plug where I can connect the OBD scanner and see what codes pop up???
Thankx
Javed
Thankx
Javed
1 fastass CL
there a lil blue plug un the glovebox pull unclip it then stick a paperclip in the plug
on both sides the turn to car on ro acc. mode n count the check light haow many times it blinks. when the light blinks slow that mean it going by 1,2,3,4,5,6,7,8,9 then when it blinks fast it the same thin as the first one but u add to it.
example. if it blike 5slow then 3fast thats mean it code 53 then you look it up and c what it is.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by starboy2nv
its located by the fan-cooled exhaust
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
(Mid-Atlantic)
(Mid-Atlantic)
What nationality is a name like Javed? just curious
Hi 97BlackAckCL,
It is basically a Muslim name, from Asia (India) a very common name in the Indian continent. Means "Immortal", i guess another word for Immortal. It is funny isn't it.
Any ways thanks for the help guys.
Later
Javed
Later
Javed
BTW the light is not comming on any more...any inoputs to that should I still hook up the OBD scanner and find out if there are any codes that show up???
Javed
Javed
Javed
Javed
good luck
(Mid-Atlantic)
(Mid-Atlantic)
At least pull the code and reset the ecu, if you have a scanner
Hi Guys,
Ok the code that came up was P0171: System too lean (Bank1). Does any one know what this means and how to fix this problem?? The car drives normal and I dont feel any hesitation. Can some one suggest some solution or checks that I should perform.
Javed
Javed
204,000+ &still REPPIN
got that same shit.
I had to clean out the EGR port, it was all blocked up with carbon deposits.
i was gonna write up some steps, but you have the 2.3 motor, i have the 3.0 and they have very different designs. But it is the same code that i had, just find your EGR and clean out the inlet holes for it. I used brake cleaner and a pipe cleaner. Codes have been gone ever since. I just wish i could turn off my SRS light now.
O2 sensor, intake manifold leak, exhaust manifold leak are likely causes of problem. O2 sensor seems most likely, but a diagnostic observation of the O2 sensor voltage trace might be in order to understand problem better.
good luck
good luck
Hi Guys,
I got the engine light on again. When I hooked up the OBD scanner this time it is showing 2 codes P0170(Fuel Trim malfunction..Bank1) and P0171 ( System too Lean...bank1). Some one told me to clean out the EGR valve & Port. I tried but was not able to unbolt the EGR assembly.
Can some one tell me how to unbolt the EGR valve??? is there a specific tool that helps do this task?? or do I have to remove a number of other components before I can get to the EGR valve nuts for me to be able to loosen them.
PLease help
Thankx
Javed
PLease help
Thankx
Javed
There are a number of potential sources of this problem. however EGR is unlikely. Best possibilities are intake manifold leak, exhaust manifold leak, or primary O2 sensor failing. O2 sensor seems most likely.
good luck
good luck
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
AcuraKidd
09-25-2015 11:18 PM
Eggs999bacon
09-24-2015 10:08 AM
