Wheel Bearings
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
That's actually pretty cheap.
One custom CL
I dont think he is talking about both Alex.
Bearing shouldn't cost more then $50. The problem is unpressing the hub from the existing bearing then repressin the new bearing in. I think $200 isn't too bad unless you can do it yourself.
-:-Jenn - O - Cide-:-
^ some shops don't do bench work like that so find out first before you decide to take it out n bring it to them. Then finding out that they won't do it.
I don't think 200 is that bad of a deal. They have to press it in & out and theres no way your going to be able to do it yourself if you don't have a machine press.
Bagel Bomber
Originally Posted by mugen_moby
It would probly be a lot cheaper if you talk off the stearing knukle your self and bring it in to them to press off and on.
I have a DiY procedure for separating the wheel hub from the knuckle. You still need to take the hub to a machine shop to have old bearing pressed out and new bearing pressed in. PM me if you want the diy procedure.
good luck
good luck
4x4- fat chicks cant jump
good luck
good luck
Sorry, I don't have a hosting site to post the file for pickup. I don't see any way to embed a pdf file into the forum. I will ask a moderator for help. If you're in a hurry PM me w/ your email address for file.
good luck
good luck
(Mid-Atlantic)
(Mid-Atlantic)
Texas, email it to BlackAckCL@gmail.com and i'll host it for ya
im not in a hurry, i actually dont really have a need for it right now. I just thought itd be nice to have it in the DIY section incase someone needs it down the road.
regards
Texas, If you are watching this thread, would really appreciate if you could email the pdf to Tony [at] TrackVision.net
I've searched the DIY&FAQ forum, but it looks like your DIY is not up there yet.
Many thanks!
Many thanks!
where is....
im pretty sure this is it.
https://acurazine.com/forums/showthread.php?t=186237
Wheel bearing
Just to give everyone an update, I had it done but as usually it there's comes out to more than you expect. The $200.00 was for one bearing. While they were replacing it the drive shaft needed to be replaced because of wear from the bad bearing and then a control arm had to be replaced. Needless to say something that was supposed to run $150-$200 ended up costing me $450.00.
(Mid-Atlantic)
(Mid-Atlantic)
Damn, does it at least drive better?
One custom CL
