What shocks are u good going on with coil overs?
Old School Ridin Clean
im planning on getting some MaxSpeed coil overs for my cl and want to know what shocks go good with it?
thanks
thanks
I.B.E.W. local 3
I would not recomend using coil-overs. I take it you want to go low, most of us use sportlines with tokico blues, they drop around 2" & ride awesome. The probelem with basic coil-overs is they tend to give you a really bouncy ride.......
if you get coilovers get true coilover systems with the threaded shocks...not the coilover sleeves like the maxspeeds that you are looking into...they will mess up your ride like crazy...i've used matrix coilovers and it messed up my suspension...if you dont want to spend more than 800 for true coilovers you should consider a spring and shock combo ...which is wat most ppl here run...
Scooby Guru
I had 300 lb/in front and 250 in back 8" long Eibach Race Springs on Ground Control coilover sleeves on KYB AGX shocks. As long as the equipment is quality, the springs are the correct length for the shocks, and the spring rates don't overpower the shocks, you won't have a problem. My car was only lowered by .75" or so with the coilovers. I could've gone as far as 2" lower but that would have killed the KYBs in no time (not to mention messed up the handling).
Originally posted by WineRed2.2CL:
<STRONG>those sportlines do not drop low enough it still looks stock man.....and i know some of u's know that. </STRONG>
Whats a good price to pay for the tokicos. I found them on nopi for $85 a piece. Anybody know of another place? Also what is the 411 on the shocks. Is the pearch different than stock. If so how much lower does this make your car?
[ 08-13-2001: Message edited by: Skanlis ]
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
brandnewcolony
09-12-2015 10:39 AM
