What Next!!!!
What Next!!!!
I'm hearing a squeaky noise coming from the front end every time I hit a bump. I've change everything you can possibly change form upper and lower control arms to all of the bushings, anti-sway bar, etc. I replaced all front end bushings with polyurethane. A friend of mine suggested that I get the front end lubed. I tried it all but this, think this will work for me??? If anyone had this done please lte me know, thanks.
Originally posted by moforose3.0
Thats the first thing I would have done (lube). Good luck.
I have the same problem. It's coming from the front right side suspension. It's kinda wierd though because it used to happen ALL THE TIME after i installed my Eibach prokit and my koni adjustables. Then it kinda stopped after about 2 months. About 2 weeks ago it started up again and it sounds even worse! It sounds like a bending metal sound and it happens when i go over a speed bump and the shocks rebound. Also, when i turn, it sounds like an old roller coaster i can be at a dead stop and turn the wheel and it kinda goes errrrr-rrrrrr (not power steering - i promise) like a bending metal sound. Its annoying and i am beginning to think that it may bew damaging something?? If i press down on the front right side of the car above the rim, it will sort of squeek too. I have put the car back on the rack to inspect, but i cant find anything wrong with it. I'm at a loss right now??
If its happenig everytime you turn and it sounds like a bunch of marbles grinding together then it probably is your CB joint which should get even louder if it's getting worse, if it is your CB joint then I suggest you get it fixed (around $500 Canadian, you convert for once
) anyways if you leave it for too, too long your axle will break and that might suck... good luck :P
the same shit happened to me, after putting my coilovers in. first it just squeaked a little bit, then the sound went away after about a week and a half. then, when i got my konis put in, it started back up. just a loud eeerrrr!! when going over a bump, or up a driveway. took it to my mechanic, he said a kick plate(?) was rubbing against the rotor, and straightened it. the sound was still there, but only a few days ago, it went away. i hate that fucking sound
Thats so ironic, It comes then it goes. I notice that when it's warm out I don't hear shit, but when its cold I hear it, what the fuck!!!
This shit started happening about 2 months after I bought it, At this point its stock. I took it to the dealer and they changed the upper control arms and it went away, so I thought. I installed the Eibach pro kit with tokico shocks and 17' rims, sound went away. a couple of months later the shit starts happening again, at this point I went to about 3 mechanics at this point had it lifted and nothing. A friend of suggested that I change all stock bushings to polyurethane and I did over the ending of summer last year.
This shit started happening about 2 months after I bought it, At this point its stock. I took it to the dealer and they changed the upper control arms and it went away, so I thought. I installed the Eibach pro kit with tokico shocks and 17' rims, sound went away. a couple of months later the shit starts happening again, at this point I went to about 3 mechanics at this point had it lifted and nothing. A friend of suggested that I change all stock bushings to polyurethane and I did over the ending of summer last year. THE SHIT IS STARTING AGAIN, AHHHGGGGGG!!!!!
Originally posted by Slooo97CL
have your ball joints checked out im pretty sure that is the problem, its also a recall do a search peace
last i heard it was a recall....i didnt pay a thing for the repair since my wheel feel off my car and my axle got cracked...everything replaced for nothing. I think the ball joints are 50 beans a piece then labor over that...
I'll check it out next week
Thanx guyz, i appreciate it! I am going to Miami tomorrow for the Winter Music Conference and i wont have a chance to check out the ball joints until next weekend - but i'll keep ya'll posted as to what the verdict is! Peace!
