what to look for when buying a cl?
I have owned 4 honda cars so far and i have always been happy with them. I usually know what the main things to look for are on used honda cars. Is their any specific problems areas on the first gen CL 3.0 that i should watch out for? Like the tranny on the second gen?
A-CL Post Whore w/N2O
Some tranny failures, power window regulators (motors), ignition switch (warranty recall), ball joint ('97--warranty recall), and emissions problems (warranty recall),
If you decide to lower your car (or change shocks/struts), the rear lower shocks mount bolts tend to rust solid. They'll need to be cut out and replaced.
ENGAGE MY VTEC BABY!!!!!!
I you decide to lower your car (or change shocks/struts), the rear lower shocks mount bolts tend to rust solid. They'll need to be cut out and replaced.
hey rick hows the court thing coming along? pm me with new details
Originally posted by 97Acura3.0CL
Joey, check your PM.
An Official Cl Whore
Originally posted by giugiaro
What are the signs of the tranny going? Burned oil smell? Bad shifting? A clunk when u drop it in gear?
My Home Planet
My tranny went out at 69K I think. I was covered under warranty luckily !
You will notice when the tranny is bad. When it is cold, it will shift very weird. It will also downshift hard all the time. A transmission flush will temporarily help the problem, but it will only get worse.
That is the only major problem I have had with my CL. It now has 79K and runs great. I am trying to be easy on this new tranny b/c I don't want to have to fork out 4 grand next time if it goes !
Is the tranny a real common problem with first gen Cl or is it just an odd case here and there? I don't know if I want to pick up a car that is notorious for tranny problems.
I think the problem is not widespread. The reason mine went I believe is b/c I do alot of city driving with trips less than 5 miles. Stop and go driving is real hard on a transmission. The transmissions are good as long as they are not abused.
100% Dominicano
navtool.com
31
11-16-2015 08:30 PM
ExcelerateRep
10-14-2015 08:20 AM
navtool.com
09-25-2015 05:15 PM
