Is this weird or what.
Old 06-09-2004 | 09:13 PM
sirchas's Avatar
Today my wife took her Acura CL ( 1997 ) to the shop to have the starter changed. They did nothing else. Now when she puts the car in D4 and presses on the gas it starts in that gear. I can put the car in one and then 2 and then D3 and then D4 and it drives fine. Other than that it starts from a stand still like in D3 or D4. Did they forget to coinnect a shifting hose or connector? To put the starter on they had to remove the battery.
Charles
Old 06-11-2004 | 06:52 PM
EricL's Avatar
Can someone help?
I don't know, but...
Can you look under the hood yourself and see if the electrical connections, hoses, etc look to be in place?
I'm going to put a copy of this in the 1st Gen Forum.
The link there is: http://www.acura-cl.com/forums/forumdisplay.php?f=114
Old 06-11-2004 | 07:08 PM
CLpower's Avatar
teh Senior Instigator
this is the 3rd time out of 3 people on this board that have gotten that fix done that have come out w/ weird transmission issues.
Old 06-11-2004 | 08:23 PM
wilp99's Avatar
hmmm... sounds like ur pressure switches r disconected or dammaged. there are two little switches just below (1" or so) the starter. if they disconnected them they may have put the wrong plug on the wrong switch. one is black and one is brown. (those are ur 1-2 3-4 shift switches.) try and look below the starter and see if maybee they put the black connector on the brown switch and vice verca. they are inter changable. like i said before one is black and one is brown. there is two wire connectors which connect to them which are also black and brown. obviously they both go togather. there is also a ground which comes from the same wire bundle the starter wires are on and goes to a bolt on the transmission. that ground grounds ALL the sensors. if that is undone none of the switches or sensors work. if that wasent the problem hit me up. good luck.and sorry for the long post.
Skirmich
10-01-2015 12:59 PM
kb1rl
09-30-2015 10:17 AM
DwDrummer
5G TLX Problems & Fixes
09-14-2015 08:20 PM
Steven Vitek
ILX
09-10-2015 07:29 AM
Quick Reply: Is this weird or what.
