weird buzzing
Old Oct 17, 2005 | 10:31 PM
sayanythingrock's Avatar
green3.0CL
weird buzzing
get in my car to go to class this morning and i start up and i hear this weird buzzing from inside the car, no a/c no radio, just weird buzzing? right when i turned the car on and then started backing out and it went away?
Old Oct 17, 2005 | 10:44 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Sounds altenator related. Take it out and take it autozone to test.
Is this the month of demise for CL's or what?!??!?!
Old Oct 18, 2005 | 07:18 AM
ajtcl's Avatar
Peace, Love & Acura
Did you have your foot on the brake? If so, it was probably your ABS Check your fluid level. You'll be fine.
Old Oct 18, 2005 | 02:47 PM
legendaryCL98's Avatar
'07 November = STI
Old Oct 18, 2005 | 03:21 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
It was your ABS module/motor running. My car does that all the time.
Old Oct 18, 2005 | 03:36 PM
SwervinCL's Avatar
Nom Nom Nom Nom
Never thought about that!
Old Oct 18, 2005 | 06:18 PM
green3.0CL
oh okay thanks guys only has happened like 2x
Old Oct 18, 2005 | 10:31 PM
wilp99's Avatar
my pcv valve buzzes. but its alot more common for the abs to be the cause like said above.. especially on the 97's
Old Oct 19, 2005 | 08:47 AM
(Mid-Atlantic)
Just hope it doesn't happen more frequently. Mine does it everytime I start my car now, I've replaced thousands of dollars worth of parts trying to stop my ABS light from triggering, to no avail. Next will probably be my ABS module, which is estimated at about 1 grand
Old Nov 7, 2005 | 02:32 PM
Pancho's Avatar
Mine does it from the time I start up intermittently for about 10 min. then stops and the ABS light comes on. Ran the DTC and got a code for High Pressure System (DTC 1-8) and High Pressure Leak (1-3). Haven't started replacing any parts yet until I find out a little more about it.
gatrhumpy
19
Dec 31, 2015 04:22 PM
dainmezron
Oct 16, 2015 06:56 PM
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
CadiGTi
Sep 14, 2015 06:37 PM
