VTec wire location??
Old Nov 24, 2004 | 01:30 PM
CL-'s Avatar
CL-
Three - Point - OH
referring to:
Originally Posted by npchottboi
yo i had the same problem with my engine...i have a 99 3.0 cl and it turned out that the vtec was bad. well mine was just a bad wiring which cause the vtec not to read. i had problems at 300 - 3500 rpm's also. the wiring was touching the cat underneath the car and it shorted it out from time to time. check that as well..
I am having the same problem and I need to know where is the wire located so I can check if mine is shorting out as well.. because my car is not raving pass 3000-3500 either
Old Nov 24, 2004 | 03:40 PM
aRIff's Avatar
Ottoman Empire
what about engine check light ? is it still off ?
Old Nov 24, 2004 | 04:31 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
make sure your oil isnt low. that will keep it from engaging. car has to be warm too.
Old Nov 24, 2004 | 05:05 PM
Mark Davison's Avatar
Big Block DOHC Type-R
Your car is in limp mode. I wouldnt say it's Vtec.
Old Nov 28, 2004 | 05:14 PM
CL-'s Avatar
CL-
Three - Point - OH
what's a limp mode?
Old Nov 28, 2004 | 07:08 PM
turbocl's Avatar
Well On A 2.2 Cl Its A Yellow/green Wire On The 32 Pin Connector,dont Know If This Helps But Try And Locate The Vtec Wire At The Sensor And Follow Back To Connector Under Hood,since This Will Likely B Another Color Going Back To The Ecu
Old Nov 28, 2004 | 07:26 PM
CL-'s Avatar
CL-
Three - Point - OH
any idea where it might be on a 3.0
Old Nov 28, 2004 | 07:50 PM
turbocl's Avatar
i paid a local mechanic shop $20 for a line diagram so i could hookup a safc.But others here should have that info for your 3.0,sorry only got for 2.2 inwhich tells me is right side of engine.If you do the same,i suggest that you go with mitchell system wiring diagram and not the others or order your copy of helmsinc for $44
Old Nov 29, 2004 | 12:34 AM
ju5tchi11in's Avatar
roomate has a CL too
that was exactly my problem when i threw the vtec pump whatever code it was. had low oil.
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
