Very Rough Idle...Why??
Old Feb 18, 2004 | 11:03 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
Hey everyone, My sister has a 96 Accord 4cyl and the thing idles like a MOFO! It just sits there and shakes real bad when its at a dead stop idling...why is this? What can i do to help it stop shaking and stop having a rough idle???
Thanks!
Old Feb 18, 2004 | 11:40 PM
d00g's Avatar
I R 1337?
egr valve? or soem sort of valve..pcv .. dont remember what its called?
Old Feb 19, 2004 | 05:43 AM
wilp99's Avatar
idle air control valve
Old Feb 19, 2004 | 07:26 AM
dragon084's Avatar
1999 CL3.0
you think thats bad... try a Hong Kong taxi cab
Old Feb 19, 2004 | 08:50 AM
Blacura1999's Avatar
hmm...could be that a motor mount is busted. Causing the engine to idle uncontollably due to the lack of being tighltly secured?
Old Feb 19, 2004 | 07:37 PM
1-cl-2-go's Avatar
A-CL Auto-Tech
check the spark plugs first, while the engine is running, pull each fuel injector connector apart one cylinder at a time. if the engine cuts off on every one each time you pull one then it could be a motormount but if the engine cuts off on all but one injector pullout, then whatever connector you have off when that engine still running thats the problem cylinder.
good luck......PM me back if you have any questions.
Old Feb 19, 2004 | 08:55 PM
DanMan1464's Avatar
Autobot
could be a timing belt? my 626 had a mis-aligned timing belt and it shook like a machine when in D at stop....in N it was not as bad
baelim
May 10, 2018 09:53 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
ceb
ILX
Sep 27, 2015 10:56 AM
IlliniAcura
Sep 19, 2015 09:31 PM
