Venom 400 un-install?
How do i take out my Venom 400, can i just undo the splices in my wires and everything will be fine???? Or can i put a VAFC in my car will it affect the venom 400???
Lots of JDM parts on my
Who hooked it up for you?
There aren't too many wires involved. I think 4. Power, ground, and 2 wires that are tapped into sensor wires. The wires were all in a gray tubing. Try to locate it out of the firewall and trace them. Just clip them at the connectors. Then pull out the rest of the wires. It's probably under your dash somewhere.
Other than the power & ground wires, there are 2 wires that the Venom400 taps into. The TPS(throttle position sensor) & MAP sensor. These should have been a simple inline tap. You should be fine by simply disconnecting the Venom 400 wires from the the 2 sensor wires I mentioned, and of course the power & ground.
Or you can just clip them, just make sure you don't leave any wires exposed.
BoricuaTL
04-08-2016 01:08 PM
InFaMouSLink
10-30-2015 09:43 AM
xsilverhawkx
09-28-2015 06:51 PM
