Venom 2000 Nitrous System
100% Dominicano
Have you guys heard anything about the effectiveness of the 2000 Nitrous System. It is marketed by venom as being the most advanced nitrious system on the market. Is it really that advanced?
100% Dominicano
Originally posted by 97Acura3.0CL
and more info on the system would be helpful, try finding links and posting them
The worlds most advanced nitrous system to date.The system is built using Venom's Patented closed loop fuel control system which ensures the proper air/fuel ratio under all operating conditions. Featuring closed loop fuel operation utilizing two dual processors to control nitrous module. Special safety features insure proper air/fuel mixture or the injection of nitrous is shutdown before catastrophic engine failure. Kit comes complete with all necessary hardware and installation instructions. VCN-2000 utilizes stock injectors for fuel enrichment during nitrous injection and is available for all late model vehicles that come equipped without a fuel return line.
Introducing the the only programmable PC-based nitrous system on the market today. A truly innovative product designed to take your car or truck to the next level of performance. adaptable to either street or track driving, Venom PC-Nitrous system is the ultimate performance upgrade with results that will blow you away. The Venom PC nitrous has several key advantages, our system is completely programmable by the end user. The user simply plugs the nitrous controller into the serial port of their PC. Using our software the user can configure the nitrous to operate in three various modes of operation.
Optimal Air / Fuel Ratio @ any Bottle Pressure
The VCN-2000 is the safest choice by far. When nitrous is introduced , additional fuel is required to ensure the proper air/ fuel mixture is obtained. Without the additional fuel the mixture would become lean causing detonation of motor. Our system utilizes the existing injectors to enrich the air/fuel mixture when nitrous is added. our systems adds an injection pulse width after the computer has finished its pulse. the pulse added is the product of how much nitrous is introduced. this is calculated by the VCN-2000 module.
Hi-Tec control module reduces the risk of engine damage
Our Control module reduces the risk of engine damage where other systems fall short. Our VCN-2000 will only introduce nitrous once it has determined the vehicles oxygen sensor is operating properly. The module determines the amount of fuel for the amount of nitrous introduced and will dynamically modify the fuel MAP based on the oxygen sensor input. The VCN-2000 uses the existing injectors for fuel enrichment.
100% Dominicano
Originally posted by Dreamdtt2000
how much will this cost?
I looked at it when I got my ZEX kit and I only really heard bad things about it, people got to confident about how safe it was and I heard of two blown motors. For the money I dont think it is even close to worth it. Also you have to know how to tune that system to get all of the benifits out of it.
What can I get ya?
I believe he was asking if anyone knew anything about this system, so if you did you wouldnt need links or pics:P
SiClone
10-01-2015 10:22 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
