vafc
I.B.E.W. local 3
I had it in my integra , it helped a lot expecially being able controling vtec activation point. You really should have it tunned by a pro for best results. I set mine up my self, i thought it made a big difference until i brought it to a shop in queens called RPM, they tunned it dope , much better than i did...
Moderator Alumnus
i dont know where the ecu is on the 2.2/2.3/3.0
i think it might be under the passenger seat, but that's just the guess. the obdII is behind the ash-tray. that probaby does not help any tho.
on a side note....
guess how off my timing is?
well lemme tell you, my car was hooked up to a obdII program, and it turns out that its running at 14.5 degrees advanced. factory spec is 12~12.5
and my intake is drawing in hot air from the engine... 168 degrees. bad bad bad. time for cold air and 60k service.
on a side note....
Ham Sandwich
easy to install.. ecu is behind the passanger floor rug.. behind a plate.. abs is on the door or infront if it.. and you just drop yer vtec to kick in whenever you want.. can't fuck anything up that way.. well.. you prolly can but.. shh
Swaps? $3000 for 50HP? :(
1genCL,
Howd you find out all the info on timing and intake temps? Would love to know that and if there are any datalogging devices for recording info like this during runs.
