Upcoming mods tomorrow
Old Aug 11, 2007 | 12:21 PM
SupraManAG's Avatar
One custom CL
Tomorrow im installing headers, pulleys, and fuel pump.
Any advice, things to look for before I install them.
Old Aug 11, 2007 | 12:23 PM
DaInFaMMuS1's Avatar
You're gonna do this all yourself? I think it'll be different for you than the regular members cuz you have an H22
Old Aug 11, 2007 | 12:46 PM
732xghost's Avatar
well i already gave you the heads up on the 19mm crank bolt. let me you how you made out with that.
by the way arber, shawn has been trying to call you.
Old Aug 11, 2007 | 01:25 PM
strawb3rri3's Avatar
-:-Jenn - O - Cide-:-
I got experience in the fuel pump part.
Unclamp all the hoses connected to the tank, prolly a breather and a feeder hose. Disconnect the wire from the trunk, unbolt the straps. I completely recommend that you drain the fuel - but it could be done without draining it.
I've raised the tank with jackstands so you can prolly do that too. Bolt up the straps that hold the tank & reconnect everything. From what I remember on all hondas. Theres a bolt that you have to torque down to honda specs. For my civic it was 34(?) lbs & I put teflon paste on the threads. haha HAVE FUn! b/c I sure didn't! :p
Oh, n try not to spill the fuel you'll smell like shit all day. hahah
Old Aug 11, 2007 | 01:53 PM
732xghost's Avatar
on accords/cl's you gotta drop the tank. its gonna be different. i stripped out my whole trunk carpeting thinking i could easily rig a killswitch to my fuel tank from my rear ashtray for security,not realizing you have to drop the tank for this to be possible.
Old Aug 11, 2007 | 01:58 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Drop the tank for the fuel pump.
Old Aug 11, 2007 | 02:19 PM
LOL I didn't think I had to type in "drop your fuel tank"
if any of you have changed a fuel sending unit on any of our cars accords n civics a like you would know that when you REMOVE those straps *hint #1* it drops the tank & why would I tell him to drain the gasoline if he didn't have to drop the tank? *hint #2 to drop the tank.
You have to drop the tank on almost all cars. Nissans, Infiniti's, Hondas all a like.
Old Aug 11, 2007 | 02:24 PM
ahhh one more thing... If your fuel pump didn't come with an o ring (fuel pump gasket). You should go buy one. Chances are your old one is prolly going to be broken or it's ancient old.
<3 g'luck
Old Aug 11, 2007 | 04:44 PM
SupraManAG's Avatar
One custom CL
I have a Helms manual. I read on it. It looks pretty simple. Only prob I might have is locating all bolts holding the tank in place.
As far as the pulleys the original size belts should fit right?
Old Aug 11, 2007 | 09:14 PM
When you take your old pulley off your old one. Hold it up to the new one before you put it on. They should be just a like (meaning bolted on just the same without any struggle).
Old Aug 11, 2007 | 10:39 PM
(Mid-Atlantic)
I was agreeing with what you said
Old Aug 11, 2007 | 10:49 PM
WHoOps!! I thought you were agreeing with ghost stating that I didn't say drop the tank. for me.
Old Aug 12, 2007 | 12:24 AM
asianspec's Avatar
when are you coming back?
Old Aug 12, 2007 | 10:57 AM
So how'd the install go?
Old Aug 12, 2007 | 04:44 PM
aha I don't know
I work a lot here. Theres a supra for sale in LA, I want it bad 14k. go check it out for me. I'm supra shopping!
Old Aug 12, 2007 | 10:41 PM
SupraManAG's Avatar
One custom CL
I installed the headers. Had to make a new dummy pipe. Shortened the existing pipe to 2.5"long. Did the pump. It was very simple. The hardest thing was removing the plastic inserts off the wheel well cover. Had a heart attack because when I threw in my sound system in the trunk I accidentaly unplugged the pump. Tried turning her over and trust me it wasnt happening. Changed the plugs. Car runs stronger. Pulleys next 2 days. As far as the belts? The pulleys are smaller and larger vs OEM. As far as I understand when one is smaller the other is larger which comes in coordinance with OEM. Ex. Original 4"power steering pulley + 4" outer engine pulley = 8" in pulleys under one belt. UR 4.5"power steering pulley + 3.5" outer engine pulley = 8". Still need someone to confirm this if possible. I should search but Im honestly too tired.
Still even after I changed the plugs the car still just dies on me. Died twice. It dies when the RPMs drop. It doesnt sound like a fuel issue anymore. Its either electrical or carbon buildups. Either ways it feels like it insufficient in one of the two.
Old Aug 12, 2007 | 10:44 PM
(Mid-Atlantic)
Damn arber, hope u figure out the stalling issue. For the pullies I know when I bought my 3.0 UR pullies they came with shorter belts, not sure about the h22's but I'd guess it's similar. Hope u figure out the stalling issue though, mine was sputtering after I changed the fuel filter but that was just cuz i had air in the fuel line. Could be the case with your fuel pump, make sure u prime the fuel pump several times b4 starting it
Old Aug 13, 2007 | 04:29 PM
SupraManAG's Avatar
One custom CL
my pulleys came with no belts. wtf. I bought all three pulleys.
Old Aug 14, 2007 | 02:39 AM
Sleep_DEPRIVED_Sleeper's Avatar
Turtle Charged, Biotcch!!
pm excelerate, he sells the belts.
Old Aug 14, 2007 | 05:20 PM
SupraManAG's Avatar
One custom CL
Bought the belts today. Gates belts. Ran me appx $30
Anyone with some brains on the stalls?
Old Aug 15, 2007 | 01:28 AM
starboy2nv's Avatar
First EVER K24 Turbo CL
sup arber... you should have checked the belt sizing b4 buying the belts, unless your sure.
does your car start then whines down? check your dist cap... used to happen to me with the old cl...
Old Aug 15, 2007 | 08:05 PM
SupraManAG's Avatar
One custom CL
nah the belts are simply worn out because of the constant power steering fluid leaking on them. since im doing the pulleys i might as well change the halvend belts. i honestly think the stalling is happening because of bad carbon buildup. Kumar. Can you ask for me or would you know how much to port n polish my intake mani and how much to chip n tune. Im in need for both of the two. I think iv done enough for this year.
Old Aug 16, 2007 | 01:08 AM
starboy2nv's Avatar
yea i can find out... i guess we'll both be dropping our cars off lol...
Old Aug 16, 2007 | 07:12 AM
dragon084's Avatar
1999 CL3.0
make sure your o2 sensor isnt fucked.
my car was stalling when the o2 went out.
Old Aug 16, 2007 | 05:48 PM
SupraManAG's Avatar
One custom CL
im getting a ported n polished intake mani
Old Aug 17, 2007 | 03:12 AM
asianspec's Avatar
happy b-day foo!
Old Aug 17, 2007 | 02:44 PM
starboy2nv's Avatar
arber i left a message.... the only time i got is sunday of next week... ill hit you oup when i can get an appointment going...
Old Aug 17, 2007 | 04:16 PM
SupraManAG's Avatar
One custom CL
thanks both for the bday n Kumar n the appt.
Kumar I heard you paying for my chip n tune as a bday present.
Find out for much man.
Old Aug 18, 2007 | 01:04 AM
starboy2nv's Avatar
LOL.... yes i shall find out..
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
Jimmy_D
Oct 7, 2015 11:52 PM
