Unoffical 400 whp thread...
#41
where is....
#42
1 Post
https://acurazine.com/forums/showthr...ht=hulk&page=3
i win.. 607 whp. 380 something tq.. i wanna know his 1/4 times
#45
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
#48
1 Post
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#49
1 Post
Thanks guys I have 2 06 RSX's to use for parts both 6 speeds just hit in the rear enough to be totalled by the insurance companies. I am doing it all myself pretty much. I have a waterjet at my disposal along with a mig and a tig. Thinking of just getting some forged pistons from diamond racing and some h-beam rods. Gonna be running an intercooler with methanol injection. Exhaust is gonna be all made of 304 stainless and mandrel bent. Convinced the wife to get a new car so I can have the CL to play with. I wanna slay some Cobras that think they are the sh!t around here.
https://acurazine.com/forums/1g-cl-1997-1999-56/has-anyone-thought-about-other-way-make-car-manual-490992/
#51
2600lb CL
^ Just wanted to add, I went through the old threads.
This thread verifies he basically ran a 13 flat, his best time as of now without hooking up.
https://acurazine.com/forums/1g-cl-1997-1999-56/got-some-new-numbers-493453/
One of the more recent threads of his is when he went at the tracks with 607whp, but broke his halfshaft. His best time that day was a 13.5 @ 118mph. Easily a 12sec car with traction.
#53
One custom CL
Really? wow I never heard that. i always heard of axles snapping at tranny but never halfshaft. wow
also i would imagine some better numbers coming out of 607whp
nothing against him... is the reason turbo lag? what could it be? does he have a traction bar?
#54
1 Post
15 inch wide slicks lmao
#58
(Mid-Atlantic)
(Mid-Atlantic)
nope no traction bar
#59
He'd still spin like crazy on street tires. Better solution is to get the proper slicks and a traction bar. If i had that setup there's no way I'd be running it without a traction bar anyway, the car probably just spins and spins the tires
#63
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
#75
For 400whp, I think there's better options out there.
If you're going to stick with a 2.4 liter K series, I'd start with a stock K24 block just to keep it OEM and Crower (not Brian Crower) I beam rods with ARP rod bolts. You're spending a lot of money on this set up, so reliability would be my top priority. The K24 has a very high piston speed and I'd keep the revs low. The block is going to be the weakest part of the build.
A friend of mine had a 480whp LS motor. It's not that crazy of a number in terms of turbo Honda's. I can't see you having much of a problem hitting your goal. Good luck with it. It's nice to see someone doing something different.
#76
1 Post
if the blocks going to be the biggest problem.. why not just sleeve it?
#77
Cheap, fast, reliable. You can only pick two. This is already an expensive project. I'd hate to see it not hold together.
#78
i'm not following this whole sleeving issue. K series have iron cylinders don't they? If they're as good as the F's, I think he can hit 400whp safely without sleeving.
#79
He said 400whp was the starting point. I'd assume he'd like to go beyond that. I just wouldn't skimp on the bottom end. I'm also a bit of a reliability freak when it comes to built motors.
#80
but to that, thats kidna wasteful in a FWD car. but lets not get into that.
