Type Of Oil???
Originally Posted by ingsoc747
I dont know if i trust AMSoil. if you do research on the internet, you come across an awful lot of suspicious posts on forums that flaunt the alleged superiority of AMSoil. also, AMSoil seems to throw a lot of propoganda out there...
I would stick with a FULLY synthetic, not a blend. Mobil-1 is good. Use 5w-30, it is what Honda recommends for your car. It's good from -30 to +40 deg C. Which should be fine for most climates.
I also get better gas mileage with it in. Someone else on the board reported the same.
I dont really care about which oils others use, but thought since there was very little info on the board about amsoil, i would throw my hat in.
Originally Posted by mdashali
I am planning on changing to Synthetic.
Can I just drain the old oil and top it with synthetic oil and a new filter or is there a procedure for the change-over.
Thanks!
Thanks!
With oil that has long drain intervals like amsoil, they recommend an engine flush. It is not necassary, but if you do not do one, you should change that oil and oil filter quicker than the recommended 25k drain interval. Because residue and deposits from the old oil are in the engine, it could cause the new filter and oil to have a shorter lifespan. The next oil change after that should be peachy.
Originally Posted by cnorwood19
Yes you can.
IIDXholic
Oct 8, 2015 07:53 AM
