Two-tone interior....
Hum........what next??
I have always been jealous of the nice dual color interior that comes with the "parchment/taupe" (or whatever it's called) CLs.
So I desided to made my "charcoal" two-tone.
I started last night and only have to complete the dash.......I need to post a how-to question on removing the dash wood and such.......
Anyway, here is a before and after pic.......sorry for the poor picture quality.......tell me what you think.
And I will be posting a full set of quality pics after I finish the dash.
BEFORE
AFTER
BTW......this was very easy, I just used Flat Black, vinyl/plastic spray dye........$4 bucks a can......I've done all four panels and still have 1/2 a can left.
BEFORE
AFTER
Thats my Girl!!
It will be very nice and something different then anyone elses but if you do that wouldent you have to dye the whole dash board???
that will be lot of work i think
Turn Signals are good!
thats pretty nice... does it make the vinyl hard at all?? or does it keep that nice squishy feel?? I would hate to see it start cracking or peeling!! I'd also like to know where that stuff can be found.
Looks good I have started on my interior/under hood as well I have a champaine colored 99 cl 3.0 and I have started doing my tan interior and making it tan/black I and a lot of people I know say it looks nice I personally like it I have also started making a few thing under my hood champaine colored as well when I do more which means I need more $$$ I will try to post pics
The panels feel the same as before.....stiil soft. I don't think they will crack! The stuff doesn't rub off either. I even tried cleaning one of them with windex, figuring I may over spray on them while doing the windows, and there was no black residue on the towel.
I bought the spray at a local auto store. Some we have here are Pepboys & Autozone. $4.00 a can. It was "Flat Black" and the brand was DupliColor. I originaly purchased a can of Plastikote "Flat Black" and sprayed one panel. It came out very glossy so I went and bought the other brand and tried it. It was much better and I re-coater the first door panel. It came out just like the others. According to the can, the stuff soaks in and bonds with the material, so it won't flake or rub off. It works on the hard plastic too, I started doing the other dash pieces.....vents and such.
Just make sure you thoroughly clean the parts!! Once the top was separated from the panel, I washed it using dish soap/water and a nail brush. This is especially important if you use any of those dash sprays like Armoral. You may want to even wipe them down with rubbing alcohal. If the dye cannot penetrate the surface, it will wipe right off.
Good luck!!
Good luck!!
blah blah blah
I couldnt' help but notice, that your 98 door panel is just one color. I have a 99 and the door and dash is two tone. The bottom is like a tan color and the top is a dark tan, or of a brown color. Maybe the 99 is different, not sure. But have you tried it on your leather seat? to make it match as well?? cause i don't mined doing my seats so it could be two tone.
is it me or i cant see the two tone or im just on crack hehe....im lost...i really cant see a difference...to me it just seems like lighting...but i could be wrong...
Stage 1 Audi S5
I haven't tried it on the seats and I don't plan on it.....sorry.
Again I'm sorry for the shitty pics.....I just finished the dash and I will try to take some good pics tomorrow....in the sun.
Thanks guys!
Hey if any of you try this yourselves, just tape of the wood trim that goes around the A/C controls. Like Ross said, it will break. There are two screw that connect the Climate Control panel the the back side of the wood and there is metal in the way of getting the screws out. You have to break it, to get it off.
wow nice pics now...hahah i can finally tell ...nice... oh and CL-z which what year accord sways did you get?
But last I checked, the damn things are still on back order. And I ordered them about 3 months ago.
Stage 1 Audi S5
Looks great. It would look even better if you bought the wood trim piece that i have that goes around the auto shifter part Never used it seeing how i have a manual but its nice Got it from www.woodtrim.com
Stage 1 Audi S5
Originally posted by CL-Z
'98-'99s already come with the wood around the shifter.
hey it's me vtecpowersumo who painted everything white...
i wanted to know how you painted your dash....
i tried taking the dash off, took like a 100 srews out.....
how did you do it.....
thanks
thanks
thanks
thanks
I dyed it in place. Take out the vents gauges and the wood where the sun-roof button is.....you can get to the two screws for the wood by removing the plastic below the steering wheel. the dash tweeters just snap out.
I taped off the end of the dash and used a plastic drop cloth tucked behind the top of the dash and windshield. Just spray light coats so it won't drip on anything else!
I've had breathing problems for 3 days b/c of the fumes.....use a mask if you can get one.
Good luck!!
