Two Questions
Two Questions
Hello;
I've got a '99 CL 3.0 and the left brake light went out. The bulb is fine as is the fuse. Does anybody have anything on this? Also, while grasping at straws and pulling fuses, I inadvertantly pulled the radio fuse and consequently I have no radio. I do have the code on the inside of the glove box, but I don't know what's required to enter it into the radio to get it working again. Can someone advise me on this?
This is a 'certified' used car (under warranty), but I hate to take it back to the dealer for anything.
Thanks -
Doug
Thanks -
Doug
Re: Two Questions
ehehe....I just had to go out and get my frickin' radio code....36 dollars at my local honda/acura dealer. One half hour labor to pull out your radio, get the serial number for it, then enter the serial number in lke a nat'l database, where they can find your code. The code is no where on the car unless this has been done before. The only way to avoid the charge i to pull the radio yourself...which isn't too bad, a friend of mine did it on his 'lude, and it's about the same kind of install/removal. I didnt do it myself because im lazy as fuck
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
