Turbo anniversary
#43
A-CL Totaled Member
Originally Posted by sumdumguy
good shit.....sounds like the future for me....
btw is there any lag?
#44
Originally Posted by xrunner86x
It makes about 5psi by 3000rpm and hits the full 10 by 3500. The power curve feels pretty smooth and if im racing the only time im not at full boost is the begining of first.
I think I'd keep mine low though, about 10psi.
#45
A-CL Totaled Member
I like this...I really thought there was no hope, and I wasn't gonna do a h22 swap, so this gives me hope.......for after my payments of courese
#46
yea well it is really tempting to turn it up, i started out saying i wasnt going over 6psi, then 7, 8, 9, 10, 11 which is max for the stock map sensor. over on honda-tech there is an f23 running 15 pounds as a daily driver and he has run up to 17 and another pushing 16psi. appearantly even our thin rods and weak ringlands can take it, the question is for how long. id rather stick to running my 8psi daily 10-11 track and have the motor last longer.
#49
A-CL Totaled Member
Originally Posted by Blenz
Can you upgrade the rods and ringlands to safely run more boost, or is there not a company that will do that for the f22b?
parts are easier to get for the f22, but again i have an f23. rods do not seem to be available and a set of pistons costs more than a used f23.
#50
#51
Originally Posted by CL Platano
True that eventhough running mad boost would be fine but boost is no good with a dead motor.
i have an f23.
#53
A-CL Totaled Member
so can this be achieved in the f22 without the upgraded parts or is there a difference?
#55
www.raceeng.com also has rods for both (f22/3) motors
#56
A-CL Totaled Member
Thanks d98 I had never seen rods listed for the F23, that site has more honda internal components than any other one i've seen. I still dont think I would ever build this motor because:
F23 rods $689
F23 pistons $449
Entire F23 motor on ebay $250
Yea so I cant run 20 psi but those are mad expensive internals.
F23 rods $689
F23 pistons $449
#57
some motor part for the f22 are at www.f22parts.com
#58
F23 rods $689
F23 pistons $449
F23 rods $689
F23 pistons $449
#61
if there is one thing i have learned with turboing a motor (3 times for me) it is well worth it to build the motor...if anything think of the longevity of it....you can also just replace the pistons and get the rods shot peened for strength...your motor will last longer and handle more boost
#63
A-CL Totaled Member
Originally Posted by ghost_masterCL
I dunno man, another $1100 and you'll have like another 100 hp.... that's almost like $10 per horse
#65
Nah its pistons and rods $1100 + misc parts + labor + 3 bar map sensor + dyno tuning for higher boost + stronger clutch + valves + engine mounts etc. Not worth it to me.
joflewbyu2
10-08-2015 11:16 AM
