Tunage
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Sick
Mom why is there two?
No numbers don't have the money for pulls, Tuning was done by us aem fic and my laptop and some pulls on the in front of the shop. when the turbos spool up in second tires start spinnin, I started out with 5lbs cus I'm just usin my wastegate springs as a boost controller I have springs all the way up to 13lbs figured I start out at 5 and work my way up to the others not that I think I need them at the moment.
5lbs we hit about 110 to 115 I' letting off in between gear cus tranny is a little on the goin out side so I have to go easy on it Ihave some better videos but for some reason they won't download..I'll see if I can't get some better one's next weekend it was so damn windy all you could hear was the wind when I was drivin by so this is all I got
where is....
damn that spool sounded great, what size turbos are you using? for twins that was quite a bit of boost lag, but i don't think you're running tons of boost because i didnt hear a bov or wastegate chatter/turbo flutter or compressor surge after you got off the pedal.
(Mid-Atlantic)
(Mid-Atlantic)
omg that thing sounds balls to the wall. I think everyone knew your tranny wouldn't hold, what's the next plan for it?
It revs up quick in first cus the tires spin real bad when I put it to the floor I have those vids but the damnthings won't download? I'm workin on them just gimme a little time
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by GhettoNinja06
That sounded pretty good, might want to turn up the boost tho.
Then again, I don't know anything about turbos.
wow... sounds amazing... i imagine more tuning is going to take place, because if you've done that much work, i doubt you're ever going to be finished tinkering... and and then, holly shit... even now, damn... props man, props...
That looks hot i looked at your other vids on photobucket the fly by in the parking lot is niice. I think thats the coolest turbo set up when your turbo blows off by the tires.
