Trick for seperating lower ball joint
Old 02-03-2007 | 02:35 PM
5-speed's Avatar
4x4- fat chicks cant jump
My dad and I are working on replacing my clutch. The lower ball joint on the passenger side is not budging with the separater that we have. any tricks?
appreciate it guys
Old 02-03-2007 | 02:48 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Rubber mallet plus elbow grease?
Old 02-03-2007 | 02:51 PM
suprachica79's Avatar
Yea, that was where I got stuck too when replacing the clutch. Take a massive prybar, wedge it in there, and it should pop right out
5-speed's Avatar
tried that
Old 02-03-2007 | 02:55 PM
(Mid-Atlantic)
Mine had to be broken out
Old 02-03-2007 | 04:00 PM
5-speed's Avatar
didnt see your post until now... we'll try that. thanks
Old 02-03-2007 | 04:49 PM
5-speed's Avatar
Done. thanks guys
Old 02-03-2007 | 04:50 PM
teh CL's Avatar
nice..i just heaved on it and it worked for me
Old 02-03-2007 | 05:06 PM
Palayah8ta's Avatar
Ciao Pho Eva eva
they sell honda ball joint removers, it took me 3 minutes and a Loud ass POP, but it worked..
Old 02-03-2007 | 05:24 PM
AgentOrange's Avatar
hahahaha, took me like 3 seconds when i hooked that balljoint remover up to my air wrench
Old 02-03-2007 | 06:58 PM
teh CL's Avatar
ya the air usually does it
Old 02-03-2007 | 09:01 PM
5-speed's Avatar
yeah i used a ghetto separator fork and rubber mallet + penetrating lube. After a bunch of lube and an hour of waiting, it popped right off.
i need air tools
Old 02-03-2007 | 11:46 PM
(Mid-Atlantic)
That's what my suspension tech used for mine, but they were so old and shitty he busted them out
Old 02-04-2007 | 12:34 AM
SupraManAG's Avatar
One custom CL
20lb hammer and a new ball joint. only $20
what r u doing by the way
Old 02-04-2007 | 01:51 AM
i need air tools
+ penetrating lube
need extra penetration ? Just get some + penetrating lub to get the job done.
Old 02-04-2007 | 09:36 AM
5-speed's Avatar
clutch
+ penetrating lube
will i need to press the lower control arm back onto the ball joint, or can I just tighten the castle nut to specs and it will be alright?
Old 02-04-2007 | 10:05 AM
SupraManAG's Avatar
One custom CL
you need to press it back in
you can even hit it back in
Old 02-04-2007 | 11:57 AM
5-speed's Avatar
okay so now we're having trouble getting the flywheel bolts through the new flywheel (fidanza 8lb). we're heating it up right now, but if that doesnt work... what? it looks like they could kinda be threaded into it, but i dont want to mess anything up. thoughts?
Old 02-04-2007 | 01:14 PM
SupraManAG's Avatar
One custom CL
dont do nothing
calling fidanza and tell them the problem
the bolts should go right in with no issue
if you do anything not accepted by them they might not replace the defective flywheel if it is
i really suggest you call them
Old 02-04-2007 | 11:21 PM
5-speed's Avatar
Done.
phew...
MrHeeltoe
20
02-23-2023 02:54 PM
08KBP_VA
10-22-2019 02:55 PM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
rhdune16
09-28-2015 12:31 PM
