TPS - Throttle Position Sensor, Questions
Old Sep 7, 2005 | 10:14 AM
97RedCL's Avatar
Intense-Reality
Question TPS - Throttle Position Sensor, Questions
Does anyone know how to clean or change the throttle position sensor. I noticed that they have the break off bolts, so you cannot just unscrew it. How would i go about getting these bolts out and if i drill them out can i get normal screws to put back in? Has anyone on here cleaned theirs?
Old Sep 7, 2005 | 02:45 PM
2point2CL's Avatar
i got this one,
take a dremel and cut the screws, so that a flathead scorewdriver can unscrew them. you can reuse them too if you really want.
Old Sep 7, 2005 | 03:17 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by 2point2CL
i got this one,
That's a really good idea
Old Sep 7, 2005 | 08:00 PM
2point2CL's Avatar
thanks bro
Old Sep 7, 2005 | 11:37 PM
ajtcl's Avatar
Peace, Love & Acura
I love the Dremell tool.
Old Sep 8, 2005 | 12:37 AM
wilp99's Avatar
they arent screws they are rivvets. no threads. you have to change the entire throttle body.
Old Sep 8, 2005 | 05:59 PM
2point2CL's Avatar
not true
Old Sep 8, 2005 | 06:04 PM
ajtcl's Avatar
Peace, Love & Acura
Is it different from 97 to 98 or from 2.x to 3.0? Just curious, it is possible that you are both right. Oh, you should have called this thread... "TPS report with no cover sheet."
Old Sep 8, 2005 | 11:26 PM
wilp99's Avatar
not true
thanx for tryin but you are wrong.
he's got a 3.0. it is true for this t/b.
maybee the 2.x, but im sure they still have the 5 point honda torque screws.
Old Sep 22, 2005 | 12:06 AM
baka_t's Avatar
The movement has started
Was your d4 light blinking at all?
Old Sep 22, 2005 | 06:36 AM
SupraManAG's Avatar
One custom CL
It seems like different year CLs have different screws/rivets. I have screws and even though i cleaned my throttle body the stoblem still persists on my H22. Tonight im taking off the throttle body off again, removing the screws to remove the TPS and dipping the throttle body in a bucket of brake fluid and leaving it overnight. People say it works like a charm. I already cleaned the throttle body and idle air control with cleaner for it but problem still persists on TPS. I later changed my TPS (one on old engine) and problem was the same. There are 2 small ports that lead to TPS chamber. I'm guessing thats the problem.
Old Sep 22, 2005 | 10:52 PM
wilp99's Avatar
make sure you take off all things that have rubber gaskets. cause the brake fluid will weaken that shit up.
Old Sep 24, 2005 | 02:01 AM
baka_t's Avatar
Did it affect the way the car drove at all?? Like it had no power?
Old Sep 24, 2005 | 08:06 AM
SupraManAG's Avatar
One custom CL
In my case Ill have a power lose. For instance at times ill rev to 3k and as im letting go of the clutch RPMs drop and as im giving it more gas to maybe get the rpms it kicks in too hard.
Old Sep 26, 2005 | 06:56 PM
97RedCL's Avatar
Intense-Reality
sorry, i havent checked this post in forever....but yes, before i changes the sensor, my d4 light would blink occasionally. Its still working so far so Im 99% sure ive got it fixed.
Old Jan 8, 2011 | 02:19 AM
fliplyricist1's Avatar
Staggered 1st Gen
want to bump this thread up. I have the replacement tps sensor in-hand, but it appears I have the 'rivets' on the stock one as well. Is there any truth to having to replace the entire throttle body and not being able to 'just' change out the tps sensor?
halp!
Old Jan 8, 2011 | 09:49 AM
(Mid-Atlantic)
I don't know the answer, but I know people have replaced their TPS sensor, not sure about the rivets
Old Jan 9, 2011 | 02:49 AM
Staggered 1st Gen
^^ thanks broski...yeah I have no clue either...I heard there's no 'threading' in the holes...so perhaps the only way around it is to use oversized self-tapping screws
I'll try and update this thread with my findings
Old Jan 9, 2011 | 01:54 PM
P0401's Avatar
can you not drill out the rivets and then replace them with new rivets?
Old Jan 9, 2011 | 04:29 PM
Staggered 1st Gen
^^ that's a thought...I'm a bit weary about drilling into stuff near the TB though, and debris in/around there
anyone replaced their tps?!?!?!
Old Jan 9, 2011 | 06:02 PM
Stapler's Avatar
If you are doing that kind of thing you are probably taking that whole assembly off of the car first and you can clean all of the debris out before you put it back on.
Also rather than using self tapping screws it's allot nicer to buy a tap and corresponding drill bit in a size used on other bolts in the assembly. Then you can just use normal metric fasteners.
I know nothing of the 3.0, but I hope that helps.
http://www.honda-tech.com/showthread.ph
Old May 25, 2013 | 08:00 PM
kf5mxn's Avatar
they are brake off heads because of the adjustment on the 2.2. new tps comes with new bolds so drill out heads, remove sensor, remove screw posts and install new tps.
Old May 29, 2013 | 12:06 PM
russell707's Avatar
I thought u cant buy the tps by itself? I heard you have to buy the whole throttle body?
Old May 29, 2013 | 08:25 PM
SupraManAG's Avatar
One custom CL
I think thats from the dealer. Im sure you can buy an aftermarket TPS only
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Randy99CL
Apr 7, 2016 06:00 AM
datadr
Sep 12, 2015 09:12 PM
datadr
Sep 2, 2015 06:46 PM
