Timing Belt
i did it at 90K WITH the water pump, along with replacing just abut every other hose and belt.. well worth it-- im at 123K and honest it runs as good as the day i bought i t
Not Fast But Built 2 Last
TB
I have done the belt on a Prelude and Accord and it's not too bad. Yes, do the timing belt, water pump and balancer belt if you have one. The only thing that really sucks is the crank pulley. It's as tight as a Nun's cunt! You didn't mention whether you had a manual or auto trans. If you have a manual, it's easy. Just have someone step on the brake with the car in gear and you can break it loose. Otherwise if automatic, the torque converter will let the engine turn, and you will need a healthy impact, or a special tool.
Good Luck!
Rick
Good Luck!
Rick
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
