for those with foglights or any knowledge on electricals
what the fuck is this
orange wire, brown connector... does it run power?
Thing is, ive got pretty much all the wiring on the fogs ready to go but they've got no power going through for some reason.
Thanks guys!
-Alex
PS - im pretty much decided that it is a power wire, and that i'll just have to splice it to something running power because our cars dont have the brown connector piece at the end...
again, any and all help is appreciated!
Thanks guys!
-Alex
U can't just tap off the battery? That's your closest option, also is the switch on when you're "not getting" power?
Just some thoughts
And where did you pull that orange wire from, behind the glovebox or something?
Just some thoughtsAnd where did you pull that orange wire from, behind the glovebox or something?
Just some thoughts
Its orange, which tells me that it is probably for power (most oranges and reds usually are)
Just making sure...
ok.
the thing is, the actual fogs have their own set of power and ground wires.
then, I guess the switch itself has a power/ground. So Whatever that orange wire is must be what powers the switch.
Originally Posted by CleanCL
are these aftermarket foglights? or stock? what kind, where did the plug come from? where does it go?
if your almost positive its power (which it sounds like it is), clip off the connector, and tap into a constant 12v source. thats what i would do.
i'd be scared of shooting 12v through it, but worst case scenario you blow out a bulb or something in your fogs.
just an update... electricals are all in check.. the actual wire assembly can be used from the civic foglight kit no problem at all
However, the only issue im going to have now is mounting the fuckers to the bumper. Ick.
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
