teaser
yo supra i saw in one of your pics that half of your gauges weren't working? That happened to me too. do u have any idea how to fix it? i have to leave my dimmer unplugged because when i plug it back in more lights go out.
i just have to replace them time to time
havent got around to it
Then you're using the wrong LEDs r cheap ones. The ones I have aren't the best but they have lasted me for a while. Most on them going 3 years strong especially my festoons. They bright us the whole dash.
I'm thinkin on adjusting the TPS and adding some tight security features. When I do those I'm going to re-register the car and use it a bit. I miss it so much
yea idk i have a feeling it might have to do something with the wiring or something. i think we checked them again and they worked. also the fact that one side of my cluster when out when i plugged my dimmer back in gives me that feeling too
did you ever think that your dimmer might be defective. i would also check the plugs but chances are one of the led bulbs isnt making contact because what i found it that current runs from one to the other and so on. if the current isn't looped thru one because of whatever reason you will not get power to the other bulbs. you might want to check that
if you post a pic maybe i can help
and yes my battery is recocated in the trunk and yes i am a noob. only invested about 15k in my car so far. yes the triple plate clutch is for a supra
nice work on the car! supermang coulda had some powered s2k seats! if you put some more work into it.
https://acurazine.com/forums/1g-cl-1997-1999-56/installed-powered-s2000-seat-493772/
https://acurazine.com/forums/showthread.php?t=493772
1. weight more
2. why, again?
lol
your came out looking real nice. did you cut and weld the brackets of your oem seats?
yeahhh i posted it up if anyone wanted to trade for stock seats. local. but nobody was interested.
uhh.. only the driver side is powered. if you didnt notice. IMO CLs is basically driving a boat anyways i dont think the weight of the seat matters or make a difference.
yeah i did some cutting and use a dremel to make some extra holes for the bolts to fit. a lot of custom work. it all paid off tho when u sit in it and take corners. no body roll at all
well i havent driven with them yet only around the lot lol
but the suspension setup is great and can only say that the seats would make it even better. kinda sad. soon i will though
hey look. its bigger than your exhaust
just repositioning and upgrading to bigger brighter bulbs
can you guess what that is?
Progress is slowly moving along but its happening.
O RLY?
