Take Out that Silencer
This is for anyone that wants to take out their air silencer and give their cl a little roar.
STEP 1
Locate your intake box and take the top half off and take out the air filter. The top is held by 4 8mm screws.
STEP 2
In the pic below you can see one of the 2 10mm bolts that you need to remove. The second bolt is down between the battery and the intake. You will need a long extension to get to it.
This is what it should look like once you remove the filter box.
STEP 3
Now turn your wheel all the way to the left and take out the bottom 2 screws that hold the plastic lining. Also remove as many of the plasitc clips that you need to to pull back the lining I only need to remove 3 of them.
STEP 4
After that pull back the lining and look straight thought where you pull it back from and you should be able to see a 10mm bolt. Remove it. Also if you look in where that u-shaped tube is there is a 10mm bolt there too.
Step 5
Once those are removed wiggle the whole thing back and forth because there is a bolt towards the front but you dont have to remove it. the box snaps on to the bolt.
STEP 6
This part is up to you on how you take it out. I separtated the U-shape tube from the box at the bottom. Them took the box out from the fender well and then took the tube up through the engine compartment.
STEP 7
Put it back together
I hope that this has help everyone.
STEP 1
STEP 2
STEP 3
STEP 4
Step 5
STEP 6
STEP 7
Great info!
Thanx.
Black '97 Acura 3.0CL Premium (Leather,WoodTrim,SunRoof Visor,Spoiler,Gold,Fogs,Air Intake,Clear Bumper Lights,Gold/Wood Pedals)
GF: Silver '01 Honda Civic EX Coupe (Stock)
Thanx.
AWD Torque Monster
the 2.2 and 2.3 is basically the same just on the other side.
1997 Black Acura 2.2 CL
Currently-
PIAAs Everywhere, PIAA 1700X, Custom Grill, Clear Corners, OE Spoiler,
5% Tints (Limo), HKS Super Dragger Exhaust, AEM CAI w/Breather,
Venom 400
Comming Soon-
Headers or Ignition, Front Lip
http://members.home.net/vx16
Currently-
Venom 400
Comming Soon-
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by typeS6S
yes they would
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Low and Slow
so essentially all you're doing is removing the air filter box and the thing behind the bumper in front of the tire? i want to do this while I wait for my cai to get here, but I don't want to screw anything up...
(Mid-Atlantic)
(Mid-Atlantic)
oyayjoe
09-12-2015 04:40 PM
