Swapin Parts
Old 04-24-2004 | 08:10 PM
roddymerritt's Avatar
RODDYS
Swapin Parts
Ok, does the new accord come with a 3.0? If it does why wouldn't things made for this engine fit our cars? Tranny, intakes, headers, ect..... What do you guys think?
Old 04-24-2004 | 08:11 PM
ju5tchi11in's Avatar
roomate has a CL too
different engine? isn't it k series? or is that just the rsx.
Old 04-24-2004 | 09:51 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Re: Swapin Parts
1997-1999 3.0CL = J30A1 designation
1998-2002 Accord V6 = J30A1 designation
2003+ Accord V6 = J30A4 designation
The J30A4 block is shorter than the J30A1 and has the exhaust manifold built into the block (no aftermarket headers--however, I'm sure there will be an aftermarket B-pipe available).
Old 04-24-2004 | 11:29 PM
RODDYS
So the shorter block made the extra hp?
Old 04-25-2004 | 11:45 AM
The extra HP comes from a bump in compression, better (more aggressive) cams, and better exhaust flow.
Old 04-25-2004 | 11:51 AM
EPS CL's Avatar
SSM Accord V6 6 Spd
So technically couldn't you swap those cams onto our engine, or am I missing something here?
Old 04-25-2004 | 12:18 PM
Think you can swap the cams. I read conversations about it on www.v6performance.net but I'm not sure if someone has done the swap.
http://www.v6performance.net/forums/...ght=j30a4+cams
Old 04-25-2004 | 03:44 PM
baka_t's Avatar
The movement has started
Nope, the cams are un swapable. The cl-s cams are the only cams that can be swapped.
Old 04-26-2004 | 12:02 AM
RODDYS
So how much bump in hp do you get from the CL-S cams?
Old 04-26-2004 | 12:05 AM
baka_t's Avatar
Not sure maybe 15-20hp. With tuning prolly more.
Old 04-26-2004 | 12:16 AM
RODDYS
Is that a hard swap?
Old 04-26-2004 | 12:23 AM
baka_t's Avatar
Read these threads.
http://v6performance.net/forums/show...p?threadid=869
http://v6performance.net/forums/show...threadid=14407
http://v6performance.net/forums/show...p?threadid=202
Old 04-26-2004 | 01:31 AM
RODDYS
Anybody else no something about the cam swap I got confused in that thread baka_t
Old 04-26-2004 | 01:32 AM
baka_t's Avatar
Basically, you need to have the cam machined so it will fit. You will need all the specs in order to do this.
csmeance
09-10-2018 09:15 AM
handsom-hustla
11-13-2015 05:04 PM
Ny1718
09-11-2015 09:21 AM
hand123
09-10-2015 09:29 AM
hand123
09-10-2015 09:27 AM
Quick Reply: Swapin Parts
