suspension problems
6th Gear
suspension problems
I posted a message a little while back (WHAT DID I DO). In that post I asked for help diagnosing my problem. I did take the car to the dealer and they said that it was the front struts (both left and right) so they replaced them. I will admit that the car does hold the road better, but, there is still something wrong. It still seems like any time I hit a bump or any imperfection in the road the wheels do what they want (the steering wheel moves on it own). The dealer said the only thing wrong was the struts. I need help, we don't have another Acura dealer in the El Paso area, the closest dealer is hours away.
HELP!!
Eric
98 2.3 CL
Inza Red Pearl
HELP!!
Eric
98 2.3 CL
Inza Red Pearl
It might be your brakes.....when my brakes were fucked up........my wheel pulled to the right when I hit the brakes at low speeds.it would also pull going over bumps.
6th Gear
I forgot, I also replace the right rim because it was slightly bent. I noticed a little difference (or maybe I just thought I did). Anyway I don't know if this makes any difference.
Eric
1998 2.3 CL
Inza Red Pearl
Eric
1998 2.3 CL
Inza Red Pearl
6th Gear
Thanks for the reply. I thought it might be the breaks too, but it happens even when I do not apply the breaks (i.e. hitting bumps when going up hills).
Eric
1998 2.3 CL
Inza Red Pearl
Eric
1998 2.3 CL
Inza Red Pearl
An Official Cl Whore
------- Well the most obvious would be that your alignment
may be out of adjustment after they replaced your struts.
------Take it to anywhere that has the proper equipment to check the alignment first.
You Fawkin Kiddin Me!
Questions:
Do you have stock or aftermarket rims?
some aftermarket rims, such as mine, with lug centering (10 or 8 lug holes) need to have spacers to adjust vibrating etc....(kinda like weights w/ high speed balancing).
Is this your first front wheel drive car?
sounds stupid but it makes a difference in driving habits and feel!
Have you checked: Tire pressure, shocks & Springs, Sways? What about boot and joints?
just some suggestions to think about!
fellow MASShole
i think i know what your talkin about ... ove some bumps my car pulls but thats really only when its under hard acceleration .... i get on it hit a bumb and WHAM wheel rips the other way ... i dunno what it is prolly should have it checked out too
MaCe
MaCe
marcelft
07-10-2018 06:17 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
MrHeeltoe
79
10-14-2015 08:47 AM
