Speed Governed at 4000 rpms??
Old 12-22-2004, 10:47 PM
  #41
-S namyaC-
proaudio22's Avatar
Originally Posted by MENACEx818
Well, today, I refilled the gas, 76, 91 Octance, High Performance
Why are you using 91? You do realize the octane ratings tell you how fast it burns right? 91 isn't any cleaner or doesn't have any more detergents than a lower octane. You must ignore the marketing BS. You also can lose a good deal of power as your engine is retarding the timing to compensate for the fact the 91 is igniting too fast (e.g. detonation).
Old 12-23-2004, 01:56 AM
  #42
What can I get ya?
moforose3.0's Avatar
Ummm, no. You will not get detonation from running a higher octane. Running a higher octane fuel in a car will almost never hurt it. In the cl, better fuel will not help. But in a car with higher compression, or forced induction its definitely a plus.
Old 12-23-2004, 02:57 AM
  #43
I'm a llama :(
Motohip's Avatar
what he said, and the higher the octane the harder it is to ignite it. If you have detonation, you need to run higher octane.
Old 12-23-2004, 09:27 AM
  #44
WayFastWhitey's Avatar
yup, thats why higher octane gas is used at the track, it has a longer burn once ignited, esp. on FI cars, you can crank the psi up a little at the track with the good stuff
Old 12-24-2004, 12:52 AM
  #45
wilp99's Avatar
its not a recall, its a waranty extension. theres a scanned copy of it on the board somewhere.
the catlyst breaks down if all the gasses arent burned before it goes thru the exhaust. ur current cat could last 6 months, or it could last 2 minutes. ur best bet is to have it replaced.
DerrickW
11-15-2015 05:52 PM
blacktsxwagon
10-27-2015 10:12 PM
RL780
10-19-2015 09:46 AM
wubly
4G TL Problems & Fixes
10-06-2015 02:45 PM
Quick Reply: Speed Governed at 4000 rpms??
