Something is wrong/need your help
Old Apr 11, 2004 | 11:07 PM
KC CL 1785's Avatar
cmng 2 a lawschool near u
alright, I have a slight problem...whenever I accelerate there is a clunking/popping/rubbing sound comming from my right wheel. It is in every gear, even on the highway...mysteriously it doesnt happen when I hit a bump or anything like that. Any ideas on what it is?
Oh yeah and me and my bro were looking at my front tires and noticed that the spacing on my front right tire between the mud gaurd/fender and my tire is smaller on the passenger side, than it is on the driver's side... and the sound comes from my passenger's side. If this matters, my alignment has been messed up for a while. Any ideas fellas?
Old Apr 12, 2004 | 12:54 AM
KC CL 1785's Avatar
Old Apr 12, 2004 | 12:59 AM
baka_t's Avatar
The movement has started
axels???
Old Apr 12, 2004 | 05:22 AM
wilp99's Avatar
check ur front hub assembly. raise the right side up with a jack, then take the tire and shake it from top to bottom and side to side. there should be NO play. if there is it could be three things.... eather the hub (less likley) or the upper or lower ball joint (most likley), which i believe there is a recall on anyways.
Old Apr 12, 2004 | 09:35 PM
KC CL 1785's Avatar
thanks, I will chck on that
Old Apr 12, 2004 | 09:38 PM
SooDARK's Avatar
05' 350z 6spd.
check your motor mounts too, I thought the noise was coming from my axel, but it was the mounts. Still saving for new ones
Old Apr 13, 2004 | 05:59 PM
KC CL 1785's Avatar
it is only when I press on the accellearator, can it still be the mounts?
