something wrong with my rear wheels?
ahnyoung!
well i was told while driving that my rear wheel was shaking. . . like wobbling or something!
whats wrong with it and why?
my tire on that was mounted and balanced when i had to change the tire too =/ soo. . . hmmmm
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Outlaw
Did you check the lugs? They might be loose.
Check the rear tires for a "bulge" by running your hand over the the tread all the way around the tires. Even pratically new tires can can a bulge or a bubble that isn't visible but would cause this.
1st Gen CL Noob
It could be a bulge in the tire.
If that is the case, the tire has to be replaced ASAP since it can blow out anytime.
Could be something else, simple such as some mud caked on the inside of the inner side of the rim.
Good luck resolving the issue.
ahnyoung!
Originally Posted by ajtcl
You were told? You could not feel it? Hmmmm, any noise?
even hard cornering. . ioino whats wrong =/
lol!
maybe the bearing but i'm not so sure -_-''
09-04-2015 08:03 AM
