Some questions about my CF hood
Old 09-09-2006, 07:03 PM
732xghost's Avatar
by the way the hood looks amazing but im just kinda pissed i cant put my grill back without drilling holes. my car is sitting in a college parking lot with the hood latch completely visible. but anyways on the drive here on the expressway i noticed that when i was going 60+ that my hood was sitting right and kept moving up and down. and why is there gaps between the hood and the headlights etc. for any of you CF hood owners could give me guidance with this matter that would be appreciated.
Old 09-09-2006, 09:06 PM
Recnelis's Avatar
first of all, there are gaps because perfect fitment isnt gonna be possible on a VIS or SEIBON CF hood... that is for the 3000 CF hoods so live with it buddy.
it moves up and down because the wind is going under the hood and lifting it up. over time, you will put stress on the latch and eventually, the latch will break off from the fiberglass, which is why people get HOOD PINS.
they are about $50 and $80 to install. gl with that
Old 09-09-2006, 09:16 PM
where is....
AznX TL's Avatar
yes hood pins are a good precation, its better to spend acouple bucks on hood pins then to buy a new hood and windshield
Old 09-09-2006, 10:12 PM
HEET Miser
duluoz's Avatar
maybe a little weather stripping above those h-lights, paint hoodlatch flat black, at least if/till you drill? i'm just guessing , gl.
Old 09-10-2006, 12:07 AM
732xghost's Avatar
thanks for the advice guys, i guess i might invest in those hoodpins, even though they look gay.
Old 09-10-2006, 02:55 AM
Alex's CL
slamed_cl_on_18z's Avatar
the hood pins will also help bring that gap down just a bit.
Old 09-10-2006, 04:23 PM
732xghost's Avatar
yea i help prevent the scummers in my area for jacking it. im gonna go take some pictures of it BRB.
Old 09-10-2006, 09:54 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,461 Likes on 3,055 Posts
That's weird, my hood had no gaps, and settled right onto the car. As for the hood, I knew about the drilling cuz of the first hoods. Be VERY careful, I cracked the first brace drilling it, and had to epoxy it back, but I had to modify the grill, by dremeling down the plastic brace on the bottom center to make it sit more flush. The hood gaps shouldn't be if your hood is molded right and your hood is centered, mine lines up perfectly. But you bought an ebay hood not the gb hood so I dunno what's up with them
Old 09-11-2006, 09:07 AM
732xghost's Avatar
i figured it would be the same as the GB hoods, because its still made by VIS.
Old 09-11-2006, 09:19 AM
(Mid-Atlantic)
Should be, are you using the stock hood struts? If not, they're in the way and need to be laid flat, that may help, or they're just flexing your hood up if they're installed
Old 09-11-2006, 10:03 AM
07 tl-s in
subbuzz's Avatar
this is a no brainer,get rid of it.i'll come dispose of it for you:thief:
on my car
Old 09-11-2006, 10:10 AM
(Mid-Atlantic)
Just like my omni's right?
Old 09-11-2006, 10:14 AM
07 tl-s in
subbuzz's Avatar
Old 09-11-2006, 10:40 AM
(Mid-Atlantic)
Old 09-11-2006, 10:58 AM
ib_jimmy's Avatar
hood pins are a must if u have a CF hood.
Old 09-11-2006, 11:14 AM
732xghost's Avatar
i put the hood struts back on. but hopefully the hood pins might level out the hood a little more.
BoricuaTL
04-08-2016 01:08 PM
CLsuperhero
09-23-2015 12:53 PM
datadr
09-12-2015 09:12 PM
mc1114
09-11-2015 05:50 PM
BookemDanole
09-11-2015 04:53 PM
Quick Reply: Some questions about my CF hood
