Some Engine Bay things i can get rid of
im bored today so im looking for some easy things i can get rid of or relocate, i already took out my (IAR) Intake Air Resonator control solenoid valve. but theres some small hose leading to a box under the air filter and next to the battery. can i take that out as well. i have a feeling FULLRACE can help me with this one.
the thing is, there is nothing under my dash. No vents, no heat/ac, no srs modual, no srs wiring, NOTHING. Its a empty space. I hid all my wires neatly behind the glove ( which i just put back on ). I also did a cruise control delete, powersteering delete,ac delete, threw out the heat, and took out any wires i didnt need to have the motor start. I looped the ps so theres oil in the rack and i love the feedback i get now when i realy drive her. I feel like im in a hornet or a fighter plane. the car goes wereever i point her.
Originally Posted by 972xghost
o man cruise control delete. i would never be able to live without that. saves me so much gas. but what about that box that has to do with my IAR
gas shouldnt realy be a big concern, its not that expensive and no matter what price it is....if you own a car you should be able to afford the gas.
Bagel Bomber
Originally Posted by FULLRACE
take it out. BTW cruise control saving you gas is a myth. It actualy uses more gas because the system is constantly making adjustments decel and accel which uses more gas. There have been hundreds of tests done to prove this. Myth busters actualy just did a segement on this as well.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Mach30SiR
Anything to back up that claim? There are different types of cruise controls, they dont all operate the same way.
one more quick question about that stupid IAR. ok i rip out that solenoid valve and that dumb little box. now i have a long hose on the passenger side of my engine bay going all the way to the back by the firewall. its just sitting there but it must be connected to something. what should i do it with it??
First EVER K24 Turbo CL
Originally Posted by Cocoa
Yeap, no cruise control over here either. Took that shit out when I had the chance at the shop. Everything sounds like my car except for the PS. I still have that. There is a bearing making a loud annoying sound by the PS pulley, so I'm considering taking it out as well.
and you didnt accept my myspace add!
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
i dont use cruise...........i cant because of the tb. I use my car for having fun only. I have a daily for pimping. ill do a diy. If you look on your IM plenum...theres spaces for 4 vacume hoses. those vacume hoses are connected to some metal parts then back to rubber. The two that are needed to run the car i used in a straight shot to were they were supposed to go and got rid of all that crap on the rear of the firewall in the engine and the metal intermediate peices, and the extra hosese, and the brackets, and the ps lines, and the ...............i took out almost everything short of ABS, which requires me to get components off a DX accord or an accord without ABS......engine has to come out again for that.
Originally Posted by Palayah8ta
ur car must be loud.. u should come out to cali so i can drive it!
Being a mile high ...elevation....shouldnt make the car sound anydifferent
Ciao Pho Eva eva
no its not that loud. It has a very Raw sound to it. I dont have some fart cannon on her.....everythings pretty mellow. Ill take sound clips for you all.
Being a mile high ...elevation....shouldnt make the car sound anydifferent![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
But u cant use your engine to its full potential.. what exhaust u using?
flowmaster muffler, 2.25 inch kteller piping with 1 res, carsound cat. Its very raw and mellow, doesnt get high pitched at all.
ill do that sound clip right now then
its some BS emissions part you dont need. its the thing that you probaly just hid somewhere when you put your aftermarket intake on.
sockr1
10-01-2015 01:31 AM
