Snow Ready
Flush, Flush, Flush!
Looks like you have just bought the CL so you must asume that all the fluids are as old as the car.
Flush and replace with the best synthentic:
Cooling system-for heating
Breaks-to stop and save your ABS
Clutch/tranny fluid-to shift
Check tires
Check/replace belts and hoses
Change fuel/air filters
Should cost around $150 to have a grarge do it al for you.
I recommend Mobil 1 for oil and gear lube (fpr bearing if needed).
"Orange" synthetic anti-freeze.
Good Luck!
Check tires
Good Luck!
Check tires
Good Luck!
Check tires
Good Luck!
Originally posted by chrisbpickering
How many miles on a car do you think this would be necessary?
neuronbob
23
07-16-2019 11:48 AM
lanechanger
10-13-2015 11:56 AM
