Shifting Question
Shifting Question
Forgive me if this has been posted, but I searched for it to no avail. i was just wondering what everyone shifts at? I try adn keep it a bit under 3 grand unless i'm really stepping on it. What is the "proper" if any, shift point for the 2.3 CL's? 1st to second and so on...
Thanks in advance!
Thanks in advance!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
8000K
Originally Posted by 972xghost
keep it under 3K to save gas and normal driving conditions
if your beating the shit out of it try and keep under the rev-limiter.
Yea I don't plan on beating my car at all, I need it to last me. Their isn't really an ideal shift plan for the cl is their? I know that in the manual it says like 15 for 1-2, 28 for 2-3 and so on, but i was just wondering what everyone else here usually shifts at or how they go about shifting. My car is completely stock BTW. I'm at the point where I can usually hear when it wants a shift.
Originally Posted by 98 CL
I usually shift at 4k- seems to be quicker between gears and doesnt seem to put any stress on my tranny
Yea on my way home from work today I shifted a bit higher than I usually do and found this to be pretty true.
Also, my car seems to be a bit "shuttery" when getting out fo first sometimes, anyone know what this could be? Maybe my flywheel needs to be shaved down a bit?
Originally Posted by SwervinCL
^ Mine does that even with a new clutch and fly.. I have just come to accept it.
shit really? Sometimes its absolutely fine if I let out the clutch fairly slow, but if I let it out quick its shutters like crazy, my whole dash would shake, I guess im glad I found this out before I went out and had my clutch and fly looked at.
Nom Nom Nom Nom
It all depends how I take it into first.
its a not a problem at all. your just not giving it enough gas. thats all.
B A N N E D
Originally Posted by zguy95135
Give it more gas when you take off in 1st, mine does the same thing unless I slip it at 1500 or so
Practice this enough and you wont have to rev to engage first from a stop. You'll know exactly how much gas to give and how fast/slow to let off of the clutch. At times when i'm not lazy I can fly through the gears from a stop w/o feeling the engagement. My passengers can appreciate that.
contrarian in fashion
really?? whoa... for some reason... im able to take off under 1500 without the car shuttering. ill try it again tomorrow morning when i go to work to make sure im not talking outta my ass!
NAWWWWSSSSSS
1 Post
Originally Posted by shineynitelite
i can take off without giving it any gas, i think you guys need to learn how to work a clutch!
Yea I can do that if I let the clutch out real slow.
4x4- fat chicks cant jump
^and youre on a flat or downhill surface
what kinda bugs? i just changed mine too, and i think we have the same setup
Originally Posted by hornedfrog2000
I still need to work some bugs out after my clutch change though...
1st 10mph ,2500 rpm
2nd 25, 2500
3rd 35
4th 45
5th 55
i dunno the rest.
Originally Posted by NauTiC*
Rev to 1000x RPM before you engage the clutch, never below that. As you engage the clutch you want to hit the gas pedal at the same rate of speed opposite to that of you releasing the clutch. Make sense?
when you drive cocoa's beast then you do it the opposite way.
Originally Posted by asianspec
i drive like grandma sometimes. i shift at:
1st 10mph ,2500 rpm
2nd 25, 2500
3rd 35
4th 45
5th 55
i dunno the rest.
1st 10mph ,2500 rpm
2nd 25, 2500
3rd 35
4th 45
5th 55
i dunno the rest.
