shifter bushings
Old Apr 11, 2007 | 03:18 PM
  #41
I Fear No Five O's Avatar
Alright, sounds good. I just wanted to make sure since the new CorSport bushings are aluminum, whereas the factory bushings are rubber. Looks like I'll be ordering the shifter bushings and the P-Spec short shifter soon. Thanks for the quick replies!
Old Apr 11, 2007 | 03:36 PM
  #42
Palayah8ta's Avatar
Ciao Pho Eva eva
the aluminum bushings are made for short shifters, thats why i wanted to try it. i have a prelude shifter.
Old Apr 11, 2007 | 05:23 PM
  #43
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Originally Posted by Palayah8ta
u can get a little packet of grease from autozone, they sell them near the cashier/counter.
A little lube ALWAYS helps
Old Apr 11, 2007 | 06:23 PM
  #44
CLpwner's Avatar
Mmmm...
<-- perfect name for that
Old Apr 11, 2007 | 09:27 PM
  #45
(Mid-Atlantic)
It's a great smiley, I never use it
This is my other favorite
Old Apr 12, 2007 | 02:34 PM
  #46
sixfifty's Avatar
I
Since when are you a mod?!
Old Apr 12, 2007 | 02:46 PM
  #47
hornedfrog2000's Avatar
B A N N E D
Hes not, he just wrote that under his name.
Old Apr 12, 2007 | 03:08 PM
  #48
(Mid-Atlantic)
You can't, try it
650 I've been a mod for about a month now
Old Apr 12, 2007 | 03:17 PM
  #49
CLpwner's Avatar
Mmmm...
hahah Boink?
Old Apr 12, 2007 | 05:38 PM
  #50
Palayah8ta's Avatar
Ciao Pho Eva eva
looks really guilty like hes boinking his cousin..
Old Apr 12, 2007 | 10:14 PM
  #51
slowCL's Avatar
So i take it they still make the P-Spec short shifter for our cars? i was under the assumption that they quit making these a while ago from reading else wear on the forums. am i wrong? if so where can i get this at? thanx
Old Apr 13, 2007 | 12:38 AM
  #52
sixfifty's Avatar
I
You can't, try it
Man, I've been missing so much.
I gotta stop by more often
Old Apr 13, 2007 | 04:18 PM
  #53
Yeah, they still make P-Spec shifters for our cars. I actually talked to the owner of P-Spec a few weeks ago and he said they're still making them and will continue to make them for a while. If you want one, check out the website at http://www.pspectuning.com/contact.php
Old Apr 13, 2007 | 04:28 PM
  #54
Palayah8ta's Avatar
Ciao Pho Eva eva
overpriced man.. i wouldnt buy them.
Old Apr 16, 2007 | 07:31 AM
  #55
agranado's Avatar
how handsome I am
have you ever shifted a car with one? obviously not!
Old Apr 16, 2007 | 11:50 AM
  #56
slowCL's Avatar
Thanks man I also heard the stock prelude shifters would work as well.... Does the pspec have a shorter throw then the stock prelude shiter do you know of?
Old May 5, 2007 | 01:40 PM
  #57
gotguinness?'s Avatar
Ok so ive got the airbox off and now im at the step where i have to unbolt the transmission housing brackets? can anyone point these out to me, it sayss its a key step so the lines wont get bent and whatnot...i just dont want to start unbolting the wrong thing. Any help would be awesome thanks!
Old May 5, 2007 | 02:08 PM
  #58
Palayah8ta's Avatar
Ciao Pho Eva eva
after u remove the E - clip and Pin, u just slide everthing off. i didnt remove the trans housing bracket. the instructions are generic.
Old May 6, 2007 | 11:55 PM
  #59
It seems like the Wire inside the rubber boot connecting to the bushing would bend, no? I juts figured i didnt want to fuck with it because it said it was a key step in order to prevent the lines from kinking.
Old May 7, 2007 | 02:25 PM
  #60
Palayah8ta's Avatar
Ciao Pho Eva eva
lol. the wire thing is meant to be bent. its called a 'cotter pin'. dont be scared.
The words of Cocoa: "cars are just like legos, but with bigger peices"
Old May 7, 2007 | 02:55 PM
  #61
I know the cotter pins are meant to bend, but I was referring to the line next to it, here, i circled the parts that i'm talking about...where is the trannsmission housing, or is it even pictured???
Old May 7, 2007 | 03:01 PM
  #62
Here are some pics i took on my phone when i was trying the install....I just noticed that i should prob clean my engine bay soon lol, everything's just becomign corroded or rusty.
Old May 7, 2007 | 03:37 PM
  #63
Palayah8ta's Avatar
Ciao Pho Eva eva
the transmission housing isnt pictures. u know the rubber things that u circled; those thigs move. So when u take tha pin out, u slide the silver ring part toward the pin part (the pin that u took out by this time). So u slide the small ring up, and the big one toward the rear of the car.
Old May 7, 2007 | 03:38 PM
  #64
Palayah8ta's Avatar
Ciao Pho Eva eva
ya know those stock bushings are in bad shape on ur car guiness. i just had an engine swap so they were really easy to take out. u might want to use some WD-40 or liquid wrench to make ur like a little easier.
Old May 7, 2007 | 04:42 PM
  #65
LOL, tell me about it...it took me a solid half hour + a shitlaod of WD40 juts to get the rusted pin out...Thanks man, appreciate the help. After taking those out it's just a matter of installing the new ones correct? Thanks again!
Old May 7, 2007 | 06:12 PM
  #66
Yea so the bushing wouldnt even fit on the shifter arm...I greased everything up more than three gay dudes and a hotel room, and it still wouldnt fit. I think i'll just contact corsport for the refund. I think it's the shifter pin more than anything.
Old May 7, 2007 | 07:31 PM
  #67
Palayah8ta's Avatar
Ciao Pho Eva eva
u sure its not on backwards? i did that too.. it will only work one way
Old May 8, 2007 | 09:48 AM
  #68
well i was assuming that the side with the larger "lip" that basically lays ontop of the circle that ties into the shifter pin was the way to do it...the rubber bushing had both sides of equal lip but the metal bushing had one side with no lip and the other side with a lip and a line carved into it.
Old May 8, 2007 | 11:30 AM
  #69
Anyone know how much a mechanic would charge to install these? Maybe i'll have him look at it ands ee what he thinks...i tried putting it in both ways with no luck and it was a bitch getting the rubber bushing out and then back in.
Old May 8, 2007 | 03:04 PM
  #70
Palayah8ta's Avatar
Ciao Pho Eva eva
thats wierd man, i put mine in like 10 minutes..
u dont live in so cal do u?
Old May 8, 2007 | 03:07 PM
  #71
hahaha well that would just be to easy wouldnt it? I'm in Boston
I havent seen to many east coasters in here.
Old May 8, 2007 | 03:50 PM
  #72
Palayah8ta's Avatar
Ciao Pho Eva eva
honestly if u took it to a shop, they might charge u for 1/2 hour of labor, which is rediculous..
Old May 9, 2007 | 10:29 PM
  #73
5-speed's Avatar
4x4- fat chicks cant jump
I just put mine on yesterday. I had a problem with the inner hole on the smaller bushing being a tad too small, so I just wrapped some 400 grit sandpaper around a small screwdriver and sanded for about 30 minutes. It finally went on without a problem, but i actually had to unbolt the shift cable bracket (PITA) like the directions say .
but... totally worth it. Shifts are crisp and solid now
Old May 10, 2007 | 12:55 AM
  #74
Palayah8ta's Avatar
Ciao Pho Eva eva
can u take picture of said PITA? for guinnessboy?
Old May 10, 2007 | 10:46 AM
  #75
That would be much appreciated, thanks guys!
Old May 10, 2007 | 08:55 PM
  #76
5-speed's Avatar
for shizzle. Ill do it tomorrow after school sometime.
you didnt have to take yours off, daniel?
Old May 11, 2007 | 11:45 AM
  #77
Palayah8ta's Avatar
Ciao Pho Eva eva
no all my transmission cables/bushings were really easy to manuever because of the engine swap. nothing was crusted on because i put the bushings in 1 week after the swap..
Old May 11, 2007 | 07:24 PM
  #78
5-speed's Avatar
oh. My stuff wasnt crusted, I just had to take of the shifter cable bracket to be able to slip the bushing on, because it fit so tight that I couldnt slide it down if it wasnt 90 degrees to the post thing.
Jul 16, 2017 07:33 AM
spoiler900
Oct 10, 2015 06:48 PM
MikeJM310
Sep 24, 2015 07:24 PM
