Shift Knob
Cleanest white cl in LA``
Shift Knob
Hey does anyone know where I can get the diagram to install the automatic shift knob on a 3.0 "99. It was taken apart and now it won't seem to go back in. anyone kno the order of the parts or anything? I need this info asap please. Thanks
98 3.0CL
i dunno if this will help, but i replaced mine recently;
1. put the plastic black handle partially onto the shift stick, place the spring into the side hole and compress it as much as you can with the chrome thumb button.
2. now push the chrome thumb button all the way in until the triangle shaped top of the shift stick is in align/directly below the grove of the chrome button while still having the spring compressed.
3. press the black plastic handle all the way down and screw in the two screws to fasten the shift knob in place.
i hope this helps
i hope this helps
98 3.0CL
actually, i just thought of an easier way to word this. ok, you should have:
1x plastic/leather shift handle
1x chrome thumb button
1x spring
2x screws
put the spring into the side hole of the handle, compress it with the chrome thumb button, then slide the handle onto the shifting stick while the chrome button is still compressing the spring. the triangle shaped metal piece at the top of the shifting shaft should fall into a groove at the bottom of the chrome thumb button. screw the two side screws on the handle to the shaft and you should be set!
1x spring
2x screws
where is....
i hope this helps![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
i hope this helps
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Dude, you can go without it, just take it off and use the push down.
But to put it back together do what they said. Just gotta get the button lined back up. Make sure you didn't loose the spring, I have an extra one if u need it
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
