Serious Traction Problems
Old Sep 13, 2001 | 02:41 AM
f0de's Avatar
Ham Sandwich
you guys know my setup.. well just incase.. 2.2cl 75 shot.. lowered.. i'm having some seroius traction problems in first gear launching.. my first gear consists nothing of wheel hops and spins.. and half of second gear.. tire pressures at 15 or 20 lbs.. and my fronts raised so i get decent camber.. i know z10 engineering will custom make me traction bars.. but just incase.. does anyone know a company that has them allready?.. or anyother suggestions.. i have toyo t1 proxie tires as well..
Old Sep 13, 2001 | 02:52 AM
KavexTrax's Avatar
f0de,
talk to Scott (Clpower), I think he can help you out...he's got a NOS setup with his black 3.0
--> scott_tomkins@hotmail.com
Old Oct 4, 2001 | 12:28 AM
shatooi's Avatar
are you spraying in first gear by any chance?? i had a 75 shot on my old 97 2.2 accord and i couldn't get any traction either in 1st.
Old Oct 4, 2001 | 09:21 PM
RidinLow's Avatar
Scooby Guru
Yeah, I can't imagine what you're going through seeing how a stock 2.2CL has traction problems already.
I think the only real solution would be a LSD. We're all driving 1 wheel drive cars now... as soon as you lose traction on one wheel, all the power gets sent there.
Old Oct 4, 2001 | 09:23 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
It's your engagement point of your NOS and your launching technique...Scott is squeezing like 70 ...
Old Oct 5, 2001 | 02:36 AM
f0de's Avatar
Ham Sandwich
h22a is slowly coming with an lsd tranny, to replace my ghd (gay honda diff).. and with drag slicks i've been practicing spraying right off the light.. like, pedal down to the floor rippin off clutch.. it catches.. i'm curious to see what runs better that or waiting till i get traction then spraying
Old Oct 5, 2001 | 09:25 AM
RidinLow's Avatar
Scooby Guru
Seeing as how the car launches perfectly when I drop the clutch at around 3500 with some throttle modulation, I'd say that you should hold off on spraying until it hooks up. There's no point in adding any power if the stock motor doesn't have any trouble breaking the tires loose.
Old Oct 5, 2001 | 11:59 AM
f0de's Avatar
Ham Sandwich
you have road tires i have drag radials.. completley different
Old Oct 5, 2001 | 05:21 PM
fastvtecCL's Avatar
fastest time 13.4@107 !!!
hey fode,
not sure how your NOS works but mine you turn the switch on and when your at 100% throttle it's on, so at the track i launch like i did without NOS than hit the button as soon as i get traction and it was worked great last night. if my NOS is already on when i hit the gas i'll spin for days
Old Oct 5, 2001 | 06:36 PM
DigiBox's Avatar
Lots of JDM parts on my
I heard those ZEX kits are pretty nice. Sounds like it does the work for you. Just go for broke.
[ 10-05-2001: Message edited by: CiLver2.3 ]
Old Oct 6, 2001 | 12:11 AM
RidinLow's Avatar
Scooby Guru
Ah, didn't notice the drag slicks. Still, if you're having traction problems, spraying isn't the solution!
Old Oct 6, 2001 | 03:41 PM
f0de's Avatar
Ham Sandwich
spraying on the launch wasn't my intention, i was just screwing around with slicks and spray.. i usually launch and around 4 or 5 grand when i have traction and a good launch i'll spray in first
mada51589
Jan 9, 2025 04:40 PM
SidhuSaaB
May 30, 2020 12:40 AM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
MyBlackBeauty
Canada
Sep 14, 2015 05:28 PM
