secondary oxygen sensor failure
I'm getting the engine code for a secondary O2 sensor failure on my father's 3.0CL.
Does this mean my O2 sensor requires replacement?
-or-
Does this mean my cat is messed up and not working properly and perhaps IT requires replacement?
Any input from you guys would be great.
-or-
Same thing happen to me a couple months ago. I could also hear a rattle coming from the cat every now and then. I took off my cat and the cat inside was all shattered. I ended up buying a racing cat from obx. Good luck
The thing is I do not know if it actually is the cat or the O2 sensor. The only thing I can go on right now is the engine code that tells me a problem with the secondary o2 sensor.
If the cat dies, is it normal for the secondary o2 sensor engine code to come on? or perhaps it has nothing to do wiht the cat and only means that my o2 sensor is dead and I need a new one.
Just want to know this before spending a couple of hundred bucks on a new one.
Thanks for the quick replies guys.
Jamus22
Jun 11, 2023 10:08 AM
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
