for the second time, help!
DOOKS of hazard!!!!
anyone know where i can find brake pads? i need to get some asap and i wanna change em this w/e.......where and what should i get?
CAFFEINE SLAVE
When I'm ready to get my new pads I'm probably going to just go with these from tirerack....same compound as OEM, but less expensive than OEM (for yours $26 front axle, $21 rear axle)
DOOKS of hazard!!!!
thanks jamz......whats the difference with oem and ceramic? better stopping power/distance? ima go check out their site now
you should look into porterfield brakes...theyre really good, especially if you drive fast and brake faster...www.porterfield-brakes.com
Not AtlCl98 or Atl-CL
but if you upgrade the pads you will need to upgrade the rotors too, since the upgraded pads will be made of a harder compound and will warp your stock rotors.
Skirmich
09-15-2015 06:41 PM
