Running Power Wire To Trunk...
Hey guys. I’m installing an amp this weekend in a ’98 2.3 CL and could use some heads up on the power wire install. Is there a pass-through already the power wire can be snaked though. I know the bottom of the rear seat has to come off and I’ve seen some threads on this, but I can’t seem to find them.
Thanks!!!
Thanks!!!
i ran my wires under the door sill, under the rear quarter panel, under the seats and to the trunk, take off the door sill and the rear seat, and you'll see the room that you have to work with
there are i think 3? in teh "ass crack" of the seat, where the top and bottom part meet. I think theyre 10mm bolts. For the bottom part, there are two clips on either end that need to be unhooked. Careful with those cause i broke one.
I just rant he wires through the center console, then ran them under the carpet over the hump in the back, then all you have to do is pull up on the bottom back seat and it should pop out, then i just reached my hands through the ski hole and pulled the wires through. Im not sure if there is an easier way but that is how i did it.
yah I have my rca's going under the center console as well, power goes under the door sill like I said before, if you take out the black felt thingie that holds your cds in teh center console you can see the room that you have to work with
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
