Rubbing Question
Old Feb 8, 2004 | 07:47 AM
drewha174's Avatar
CL- SMOOTH
Rubbing Question
I changed from 215 45 17 to 225 45 17 and the rear right side rubs. I checked and don't see anything. Can someone please tell me or advise on what to do....Thanks
Old Feb 8, 2004 | 11:58 PM
lowpost's Avatar
if it's rubbing on the inside of the fender, shave it/cut it /bend it
if it's rubbing against the strut, nothing you can do but go back to 215's
Old Feb 9, 2004 | 12:08 AM
baka_t's Avatar
The movement has started
Check to make sure all your gromets are in one of them mite of came out and the plastic is rubbing. This could be the case since its only rubbing on one side.
Old Feb 9, 2004 | 12:12 AM
wilp99's Avatar
its probly the upper control arm for the rear. it comes pretty close to the tire. maybee a fingers gap away. if that is what is rubbing then ull need to get narrower tires.
Old Feb 9, 2004 | 12:49 AM
baka_t's Avatar
Woops i didn't see he said rear. When is it rubbing only over bumps??? if its rubbing the controll arm, you should see some black on it.
Old Feb 9, 2004 | 10:04 PM
drewha174's Avatar
CL- SMOOTH
It's the right rear and I hear it rubbing only when going over bumps potholes etc....
Old Feb 9, 2004 | 10:06 PM
drewha174's Avatar
CL- SMOOTH
Sorry, but what's gromets ???
Old Feb 9, 2004 | 10:26 PM
baka_t's Avatar
Ah disreguard that statement i thought you were talking about the front.
Old Feb 10, 2004 | 11:45 AM
lowpost's Avatar
oh yeah I meant control arm, not the strut
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
navtool.com
Sep 25, 2015 05:15 PM
