On the road again....
Old May 12, 2003 | 05:59 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Been messing around with the EMS and FJO wideband. Got the idle and vacuum side of all the fuel maps pretty well dialed in. Drives much better than before even with the timing maps and fuel maps still needing to be tweaked (just a matter of time).
Heres a snapshot of one of the first boost runs.
You can see I still have some fuel to add (varies from 12 to 14 a/f ratio under boost here). A couple more days with the wideband and I'll be set.
The engine load is the 3bar sensor reading of boost level (it varies from 9 to 12 while the crappy autometer gauge is dead nuts at 10psi). I tend to trust the 3bar sensor a little more than the guage.
The thing to notice is I'm at 40% duty cycle on the injectors at 10 psi which means I've still got plenty of fuel left even at ~10 psi.
Keep in mind this is one of the first boost runs and is not where intend to leave it (need to get fuel at 12.5 for all of the boost levels).
Things to note with the EMS:
This unit is not impossible to tune. On the other hand it is not for everyone. The base maps that are out there worked fine on my car. Got it running the first day with very little work. However the maps for the f22b1 are limited and there arent ANY with a 3 bar MAP and 500 cc injectors.
Automapping has the car running like stock in the normal driving ranges (vacuum and low rpms). I've used it the boost ranges but the loads and rpm vary quickly and is hard to stay in the respective ranges long enough for the unit to correct itself, but this is only my 1st attempt at boosting.
The car is running now with none of the headaches I've heard from other EMS users (idling high or dieing at stops, etc.).
I wouldnt recommend trying this standalone without a wideband though (I dont even see how this would be possible).
Cliff notes:
Got boost again.
Need to work on fuel and timing maps.
EMS is very doable.
Automapping does the work for you.
Setup:
F22b1
Golden Eagle Sleeves (85mm)
Crower Rods
Wiseco 8.8:1 Pistons
AEM EMS
FJO Wideband
T3/T4B (Modified FMAX kit)
500cc RC Injectors/255hp Walbro/AEM FPR
Quaife LSD
ACT Extreme PP w/Street Disc
DSS Stage 2 Axles
Accel 300+ Ignition/8mm Magnecor Wires
Old May 12, 2003 | 06:51 PM
KC CL 1785's Avatar
cmng 2 a lawschool near u
I was actaully thinking aout you earlier today. I was wondering if you had been to the track yet? If so what did you run? And if not, HURRY UP AND GET DOWN THERE!!!!
Old May 12, 2003 | 07:08 PM
haiduc's Avatar
Moderator Alumnus
the autometer a/f gauge is decent enough with some appications, but it does become inadequate under lots of boost/nitrous. but hey... whaddaya want for $50.
haha..... i was looking at the injectors also.... so when you gonna do 15lbs
did you pull in 2nd gear or 3rd?
is this the bulit block? or still got the stock one in there?
Old May 12, 2003 | 08:10 PM
niedejb's Avatar
15 psi will be the minimum on run on this engine (the built one).
Thats 3rd gear, but just trying to tune not going for anything else right now.
Track will definately happen after the dyno session.
Acura-C and I will make it over to Cordova sometime this summer.
Old May 12, 2003 | 08:36 PM
KC CL 1785's Avatar
you are a tease, I ahve been waiting for months now
Old May 12, 2003 | 08:41 PM
niedejb's Avatar
Im worth waiting for....
Old May 12, 2003 | 09:39 PM
d98clturbo's Avatar
Old Timer
its good to hear that you have your car back on the road..
damn my high boost will be like your low boost....mad props kid
ps thanks for helping me with that remote boost controller switch...it works wonders
Old May 12, 2003 | 09:44 PM
niedejb's Avatar
Its almost sickening thinking they charge $100 + for those switches.
I havnt even gotten to use my switch on the new setup.
Thanks for all the feedback guys.
Old May 12, 2003 | 09:56 PM
shatooi's Avatar
i have just one question niedejb, you've invested so much into the motor, but no suspension setup??? unless i am missing something, i dunno. i'm just curious if you haven't lowered the car already, how come?? by the way, congrats on ur new setup, i hope you get what you were lookin for with it and then some
Old May 12, 2003 | 10:03 PM
niedejb's Avatar
Its now on nuespeed sports with stock shocks, but it didnt make it any faster.
Need to get some new pics....been too damn busy.
Old May 12, 2003 | 10:28 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
hey don't forget meeeeeee I only live 20 min's from Cordova, i am plannin on going..... Once i get this damn engine running that is!
Old May 12, 2003 | 10:33 PM
niedejb's Avatar
I'll let you know once we get closer.
Hope you know it goes against my better judgement to even talk to someone who has more than one over head cam.......j/k
It'd be cool to make it a small meet or something. The more the merrier. Someone bring a tow truck 'cause I'm not going home till its broke or I hit 12's.
(I know this will require an H22/23 tranny which I'm currently in the market for).
Old May 12, 2003 | 11:05 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
Congrats!
BTW: How are you planning to get all of that power down on the pavement?
I ask because without drag radials, my car just sat there and spun like mad (both on stock and Kuhmo radials).
My Nitto NT Extremes seems to grip a little better, and the 555's (drag radials) make me worry that I'm gonna snap an axle.
12's, huh??? Looks like I need to rethink my strategy to keep up with 'ya. :P
Old May 13, 2003 | 05:12 AM
niedejb's Avatar
I know I'll need new tires for sure. Have a ways to go before I hit the track.
Need to have 3" exhaust welded together, finish tuning (& dyno), then get tires.
Its a slow process, but I'm getting there.
Old May 13, 2003 | 09:04 AM
ACURA-C's Avatar
Definitely, the more the merrier. A little more 3.0 representation would be nice...:P Getting spanked by all you 2.somethings will be tough to swallow. I may have to bring the R6 instread...LOL
Let's plan early enough....I'm there man!
niedejb, your car is definitely lookin good!! Cant wait to see it on the track!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
baelim
May 10, 2018 09:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
mars
Sep 28, 2015 11:03 AM
