ride height uneven
ride height uneven
the driver side it alot lower than the passenger side. fnt left has 1 finger gap rt has2 finger gap. rear left has 1 1/2 finger gap and right has 3 1/2. set up new speed sports with agx. passenger seat isnt in right now but is cant make that much differnt can it? my bro prelude was the same way but not as much of a difference between sides
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
well take this into effect. It's completely normal. There is more weight on the drivers side for a few reasons, one all the steering components are on that side, they try to do a good job at balancing it out but it usually doesn't work. Also, are you a big guy? Even if you aren't there is that extra weight from you on the driver side which in time will cause your springs to settle more. My car is the same way, esp. after I changed out the stock exhaust the aftermarket is so much lighter that that side popped up a little more.
Your's sounds a little big, but it's normal.
A-CL CrAckHeAD
Are the agx's adjustable? If so - you may have one set differently than the other? I have the Koni adjustables and i can set them on different perches for a different ride height - i dont know if the agx's are that way??
Location: Somewhere between here and there, yet neither.
You might have a bad install, like the spring isn't sitting correctly or one of your struts might be blown. AGX are not height adjustable.
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
