Replacing Timing
Old Apr 6, 2004 | 02:02 PM
Smalls's Avatar
Insert Sarcasm Here
Replacing Timing
I got an estimate on replacing my timing belt (108,000 miles) The book says 4.6 hours, @ $60 per hour, plus parts. Also, add .3 hours to replace water pump. Im looking at about $700 for the timing and water pump. How does the compare to your expirences? Is this a good price? Thanks
~Smalls~
Old Apr 6, 2004 | 02:34 PM
dragon084's Avatar
1999 CL3.0
try and reason with em.
that seems a little on the steep side
Old Apr 6, 2004 | 04:21 PM
Smalls's Avatar
Insert Sarcasm Here
Ok, Called a couple other shops
1st shop- Returned my phone call and said it needed a special tool, and they wouldn't touch it.
2nd shop- Timing Belt, Water Pump, anti-freeze, tax included $550.14
Old Apr 6, 2004 | 06:12 PM
uiskibum's Avatar
its paid for
I had my timing and water pump done through an acura mechanic and it was about $600
Old Apr 6, 2004 | 06:21 PM
Stapler's Avatar
500-600 is what it goes for around here. Depending on the shop. The local bmw shop doesnt even charge 60 an hour.
Old Apr 6, 2004 | 08:43 PM
joeshmoe's Avatar
My Home Planet
See if your local Honda dealer will do the job for less. Otherwise, just go to the cheapest mechanic that you can trust. That one shop that said you needed a special tool probably doesn;t work on hondas anyway. There's really no need to specifically go to the Acura dealer.
joeshmoe's Avatar
My Home Planet
Originally posted by joeshmoe
See if your local Honda dealer will do the job for less. Otherwise, just go to the cheapest mechanic that you can trust. That one shop that said you needed a special tool probably doesn't work on hondas anyway. There's really no need to specifically go to the Acura dealer.
Old Apr 6, 2004 | 09:40 PM
Stewie_RENAMED's Avatar
$700 seems high.
As I recall, I got the timing belt & water pump done along with front brake pads, a full tune up and transmission flush for about $1000.
Old Apr 6, 2004 | 09:50 PM
Cocoa's Avatar
2600lb CL
I payed $400. And they installed my UR pullies.
Old Apr 10, 2004 | 01:21 PM
BeeTee2's Avatar
SC, please
The Acura dealership in the Saint Louis area is going to charge me $900, and that's why a 10% discount... I'm going to start looking around for shops that will do it for less, because the belt alone only costs like $40...
csmeance
Jan 7, 2026 06:25 PM
mada51589
Jan 9, 2025 04:40 PM
Skirmich
Sep 15, 2015 06:41 PM
V12 Inspire
Sep 10, 2015 04:46 PM
asahrts
Sep 4, 2015 05:55 PM
