Relay for Fog Lights
Just bought some aftermarket fog lights from Canadian Tire and have a thought. The switch that comes with the kit looks pretty cheesy, I want to wire the lights right into the regular headlights, so when they turn on, so do the fogs.... Do I need a relay or is it as simple as splicing into the main headlight wire?
Swaps? $3000 for 50HP? :(
I wired my relay into the corner lamp wiring so they come on with the parking lights (I use the switch it came with to overide them). Wouldnt do it either way without the relay. You can always put the switch out of sight like in the flip up tray under the radio, glove box, etc.
I spliced mine into the low beams with a relay on accident ment to put them on the paring bulbs but i will fix that soon. Guess that a good reason not to drink a bottle of aftershock b4 you work on your car
Regarding the relay; Any special technical specifics I should be looking for? Is it something I can pick up at the local Radio Shack or something
instead of wiring my relay into the parking lights or headlamp wires, i put it in under the fuse for the power windows/sunroof in the fuse box.
This way, i can have the fog lights on with out the headlights, and i never have to worry about forgetting to turn them off because they go off when I open the door with the car shut off, or 10 min. after shutting off the car.
[ 08-21-2001: Message edited by: UDMechE ]
i thought about doing that but changed my mind cause i dident want them always oon with the car. Besides thats where i have my remote wire for my amp coming from since im still runnin with the stock head unit
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
