Rear lip question
clustomized
Rear lip question
I searched "accord rear lip" and read all of the threads top to bottom but want to get a definitive answer because everything i read was conflicting..
Will the 94-95 accord rear lip fit without any modification other than the exhaust pipe area?
if so, its on!!!!
if so, its on!!!!
In the middle to get the fitment right. I didn't have it done, Percy (subbuzz) had it done on his car. I transferred it over to my car and it still needs perfection - it will be molded on for a perfect fit.
Yes, only an exhaust cut out...the trick is fitment.
https://acurazine.com/forums/showthr...451&highlight=
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
It won't fit without modification
worki o w projct..
needs modification, the lip would need to be cut about 1-2 inches.. you could mount the lip with out modification but it'll look like seeing as how it'll have to sit higher and wont line up with the rest of the car at all.
We've got ours at nearly the same angle I think tho...
My rear lip lines up fine with stock skirts....Not so much with the WW ones tho.
That was my reference guide for installing the rear lip.
clustomized
thats this one right? http://cgi.ebay.com/ws/eBayISAPI.dll...m=360108246006 was it a perfect fit, or any mod needed?
basically you have two options. You can either cut it or not. If you dont, the lip has to sit higher on the rear bumper, the lower it sits, the more you have to cut it. I had about 2" cut from mine in the middle. I would recommend doing it right and getting it custom fitted to your liking.
the 94-95 mugen rear lip needs no modifications besides a cutting a couple plastic pieces for the lip to fit all the way in. And no mod is needed for the exhausts. It prolly took me 5minutes to do the cutting and intalling. It aligns nicely with stock side skirts too.
obsessedmotors
09-10-2015 10:49 AM
