Re- Surfacing Brembo Cross/Slotted Rotors
CL- SMOOTH
I'm feeling a little vibration when applying the brakes. This happen B4 I installed the Brembo rotors, the reason why I changed them. Can you cut/resurface Brembo cross/slotted rotors ???
Gimmie my points Biatch!
Re: Re- Surfacing Brembo Cross/Slotted Rotors
Re: Re: Re: Re- Surfacing Brembo Cross/Slotted Rotors
about how much?? Thanks
CL's need steroids
Doesn't sound right. Did you look at them are they groved? Are they discolored? Did you try changing your pads? Are you pads loose in the caliper? I can't see Brembos warping already. Out of balanced wheels and different tire pressures can do that also. Definitely look at other possibilities b4 you resurface your rotors... Thats my opinion
