radiator smoke??
have u open it (while its cool) to see if u have enought fuild in there? u sure its coming from ur cap? u might need to get a new cap, its part of the tune up.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by ruin
just filled it up. should i wait for it to recurculate or could it be more serious.
One custom CL
there is a little bit of smoke coming out of my radiator cap what does this mean? ![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
lol whats up with you and your coolant.
The seal on your cap is bad. Simply run to the nearest auto parts store and get a cap. Should run you no more then $15
One custom CL
The coolant gets so hot that it will turn to steam once out of the stream. The radiator cap is designed so it won't allow fluid or steam to escape which would cause a leak hence a drop in pressure. The seal sounds like your issue but I would constantly check your coolant level untill you know its not going anywhere.
